Gear oil
Discussion in 'XJ DIY How-To Instructions' started by Joe34, Sep 29, 2017.
  1. k-moe
    k-moe Pie, Bacon, Burbon. Moderator Premium Member
    Dust in the Wind
    Which direction were you turning in, and how quickly?
  2. Jeremy Washburn
    Jeremy Washburn New Member
    Kansas City
    To the right both times and around 20 or something like that and the second time was less than that
  3. k-moe
    Dust in the Wind
    Check the routing of the wiring harness near the headstock and headlight. Look for a loose plug or worn insulation.
    Chitwood likes this.
  4. Jeremy Washburn
    Kansas City
    You think it's something to do with the headlights wire harness? I did install a led headlight. The bike will start right back up after it dies.
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Turning the bars could wiggle a loose plug connection, or cause a worn wire to contact the frame, causing a short. Once the bars are straightened, the electric faries might be free to roam and perform their magic.
    Jeremy Washburn, Chitwood and k-moe like this.
  6. k-moe
    Dust in the Wind
    ^that^. It could also be floats set too low, but that would cause a stall when braking in a straight and when turning in any direction at low speed.
    Jeremy Washburn and Chitwood like this.
  7. Jeremy Washburn
    Kansas City
    Thanks I will update when I get the chance to check it out. Hopefully this weekend
