Going to check it out tomorrow
Discussion in 'XJ Technical Chat' started by Dondada469, Sep 24, 2012.
  1. Dondada469
    Dondada469 Member
    Vista, CA (North County San Diego)
  2. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Offer him less you can always offer him more.
  3. TIMEtoRIDE
    Rusty brake lines?? Bring a plate glass from a picture frame to check for tweaked forks and a compression tester.
    Budget in tires, brakes, fork and carb rebuild, a muffler, a gas tank . . . I'm scared !
  4. murray
    murray Member
    Sydney Australia
    What do you do with the picture frame glass Time ?
  5. Dondada469
    Dondada469 Member
    Why would I change the muffler and gas tank? I couldn't care less about a few dents. I just want a commuter. I'm expecting carb rebuild and brakes going into it.
  6. wwj750
    wwj750 Member
    central minnesota
    The glass Time is referring to is to lay across the fork tubes to see if they are tweaked. Emphasize all the work that needs to be done & I'm betting they'll take maybe $300 cash. Go for it.
