I want to see pics of XJ rear tires!
Discussion in 'XJ Modifications' started by Heyitsme, May 15, 2013.
  1. Heyitsme
    Heyitsme Member
    Seattle, wa
    Whether your building a bobber/chopper/cafe racer or your a purist I want to see the different tires you guys have put on. To me, nothing looks better than a fat low pro tire on a motorcycle, so Im looking for some inspiration.
  2. Heyitsme
    Heyitsme Member
    Seattle, wa
    Ill start it off. Heres my 700 maxim, currently.
    [​IMG][/url][/img]
  3. tiratoshin
    tiratoshin New Member
    nebraska
    I was really hoping for more action in this thread...
  4. Polock
    Can't really squeeze a big tire in these swingarms, try kzrider.com they swap swingarms and use those big tires
  5. skylrk62
    skylrk62 Active Member
    Illinois
    I feel your pain with trying to get people to participate on a tread.
    Here is mine. It's a 1995 XJ900S Diversion wheel from Europe with a 150/70R17 sport tire on a 1982 Maxim swingarm converted to monoshock suspension.
  6. kleraudio
    kleraudio Member
    Erie, CO
    I sent you a PM!
  7. strat
    strat Member
    Williamsport, PA
    my xj700 with a 130 rear tire...
  8. farmer
    farmer Member
    any pics of the clearance of the tire to the swingarm? would a 160 work or is the rim not wide enough? How does the diversion rim allow a wider tire than the stock rim? Is it because it is a 17 inch rim ? Can the stock swingarm be modified to allow additional clearance for the tire?
  9. skylrk62
    Illinois
    It was a tight fit, but no rubbing. I think there was a few mm offset on the rim, but honestly I can't tell. I built the rear frame around the swingarm after the wheel was on. I've ripped it up and down the streets and it handles a million times better than stock. In fact, I put it up with modern bikes. The frame strength and flex is what holds it back now. But it's pretty stout. I'm R&D it now for stress and tearing it all down and making adjustment/fabrication before powder coating the frame.
    I don't think a 160 tire will fit without some cutting to the driveshaft side of the swingarm. I think the 150 is a big change in apperance from the old style. To go 160 on the tire, you have to go with a lower profile tire and it doesn't look right, I think. A 170 sport tire will not work and those are the most popular sizes. Dunlop Roadsmart tires are what I'm running and have excellent grip.
  10. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    My stock 1982 xj750 r
  11. strat
    strat Member
    Williamsport, PA
    I believe there was a thread on here where somebody had run a 150 tire on a virago spoked wheel with no mods to the factory swing arm/driveshaft.
  12. webofdeception
    webofdeception Member
    minneapolis
  13. lance4211
    lance4211 New Member
    Sturgis, MI
    heres my 82 xj650 seca just prior to paint
