Main Fuse Mystery
Discussion in 'XJ Technical Chat' started by GKG, Oct 19, 2018.
  1. GKG
    GKG New Member
    Kelso Washington
    Hey all...Every schematic shows a Main fuse about an inch away from the battery. (81 xj650) Is this fuse invisable? Do I need special spy glasses #xb¥₩μ ?
    Seriously I have opened the harness to the handlebars and no 20 amp main fuse.
    My idiot brother plugged headlights into ignition plug and it cranks but no fire. Should the r/w wire coming out of solinoid be hot? Cuz its dead. Not the fuse box r/w tho. Brother hangs at sunset if I cant get help. Thanks..
  2. Polock
    a schematic shows where things are electrically, not physically. the main fuse is with the rest of the fuses on the fuse block
  3. chacal
    Harsh, but understandable.
  4. GKG
    GKG New Member
    Kelso Washington
    Then why not just put the damn fuse box with an arrow pointing to #1?
    Sparkys are next on the hanging list.
    I'm out working on it now..any ideas on why no power out of solinoid to r/w wire? Does solinoid send power to ignitor? Coils? Relays?
    Why are there a hundred and forty twelve wires for a headlight and 4 #$$#" turnsignals and a horn???
  5. Polock
    i think 30 odd years ago there was.
    are you really going to make me get out the book and follow those little lines? i hate you :)
  6. Polock
    kill switch and ignition make r/w hot
  7. GKG
    GKG New Member
    Kelso Washington
    You rock Polock.
    I had just pulled ignition (which consists of a hole a half inch wide screw driver fails to fill sans key) and will track down ohm specs for that and kill switch. Still bugged by no power out of solinoid r/w yet it cranks starter just fine. Your valuable time is very much appreciated Sir.
  8. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    GKG,
    Your lucky day........entire XJ650G wiring diagram..........
    This diagram is from the official Yamaha XJ750J Service Manual ( LIT-11616-XJ-71 ).......the XJ650G Service Manual is ( LIT-11616-01-94 )
    Happy tracing.....fun stuff
    Now, remove the noose around your brother's neck.
    Polock,
    Now he can follow those little lines........instead of you......
  9. fiveofakind
    San Diego, CA
    GKG,
    PM me with an email address & I can send the .jpg file directly to you. The image that you save in the email will be a lot sharper than this attached file above.....
  10. Polock
  11. fiveofakind
    San Diego, CA
    That is great
  12. GKG
    GKG New Member
    Kelso Washington
  13. GKG
    GKG New Member
    Kelso Washington
    and Thank you thank you thank you..
  14. GKG
    GKG New Member
    Kelso Washington
  15. GKG
    GKG New Member
    Kelso Washington
    A bit late on the hangin . lol.. He is buying whatever melted though..
  16. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    yeah, he said PM him.
    I'd suggest you edit your post and remove your email from this public forum
  17. GKG
    GKG New Member
    Kelso Washington
  18. GKG
    GKG New Member
    Kelso Washington
    That is the coolest gift ever. Thank you
  19. GKG
    GKG New Member
    Kelso Washington
    Yeah..i was doing 2 things at once...thanks..
  20. GKG
    GKG New Member
    Kelso Washington
    And too late..lol..i am seriously too tired to care..thanks again Rascal..
