Minimum wiring with diode?
Discussion in 'XJ Technical Chat' started by Thrasher, Jan 17, 2020.
  1. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Should the Minimum wiring have a diode in it somewhere, if so where?
    not needed with min wiring.
    you would need a diode for oil light bulb test when starter button is pushed . you will need a resistor to make oil light work with the diode
    diodes are for relays and test lights.
  3. Thrasher
    Thrasher Member
    Great, I only have head and tail lights.
