need advise
Discussion in 'XJ Technical Chat' started by mikey2021, Sep 18, 2012.
  1. mikey2021
    mikey2021 Member
    hannibal mo
    I rode my 82 maxim 650 yesterday and it ran great and I got up this morning and it would not start it turns over but nothing happens I noticed that when I put it in gear and hold the clutch the bike can barely move but it still wont start in neutral if someone can give me some ideas that would be great
  2. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    The following questions may seem stupid but I'm asking anyway!
    Do you have any spark?
    Is the neutral light on when in neutral?
    Also check the side stand safety switch. If its bad nothing is going to work.
    Oh yes do you have power to everything when you turn on the ignition switch.
    Are your brakes releasing? If the brakes are sticking the bike will be had to move.
    I think that's all of the stupid questions!
  3. mikey2021
    mikey2021 Member
    hannibal mo
    Yea light comes on I grounded the plug wires they spark kickstand safty is off um I use 20w50 motorcycle oil I don't understand how my cable could get lose from sitting one Nightingale confused and frustrated
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Maybe water in the gas. Open the drain on one of the float bowls and see what comes out.
  5. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    The clutch is subject to the cold oil it's sitting in and unless the bike is running it will feel like a mild brake anytime you are trying to roll the bike in gear.
    Good starting procedure which always works for me:
    Always switch your petC to prime for a few seconds before you try and start, then full choke and don't just crank away. If it doesn't start on the first 5-7 revolutions, stop & wait a few seconds then repeat. Once running open the throttle to get the vacuum going and should be all good.
    Be sure and check the obvious things first-I was riding in heavy traffic the other day when it was hot and my bike started to sputter and cough, I was scared it was overheating as it was really hot and I had been stuck below 10mph for about 10min. Finally it died and sounded just awful when it did. I pulled off the road and began to contemplate walking home and coming back to pick up the bike. Then I looked down and realized I was at 110miles on the OD and still at 'on' as in 'no gas'! Oops, basic stuff but we all forget sometimes.
  6. mikey2021
    mikey2021 Member
    hannibal mo
    Yea I thought the cold weather could be effecting it its been about 50 degrees when I go to work I got off work and it started up on the first crank
  7. bigfitz52
    Mikey; howzabout a little more background on this bike?
    "first bike build in progress" leads one to believe there may be modifications involved--
    how about giving us a tad more to go on? Miles, mods, your history with the bike, etc. It all helps. It's even MORE helpful if you could put it into your sig so we don't have to keep asking.
  8. mikey2021
    mikey2021 Member
    hannibal mo
    Sorry 82 650 maxim no modz all stock 8500 hundred miles its ran fine all summer and this was the first time it struggled like I said I got off work and it started right up it just got an oil change vavles put in spec carbs completely taken apart and new throttle shaft seals new battery its about 3 months old
