Oil filter element removal from housing
Discussion in 'XJ Technical Chat' started by Yx600 86, Jun 15, 2019.
  1. Yx600 86
    Yx600 86 New Member
    London
    sorry for what may be a dumb question but as a new yx600 owner I thought I’d give the bike an oil and filter change. I’ve removed the filter housing but uncertain how the element comes out. I can see a pin going through the inside of the long retaining bolt, is it something to do with that?
  2. Toomanybikes
    Tsawwassen bc
    It should just pull off the bolt. There is a washer and spring behind it. Only thing holding it on is friction of rubber Center of filter.
  3. Yx600 86
    Yx600 86 New Member
    London
    Brilliant thanks- didn’t want to force it
    Cheers
    City of Seven Hills
    You may need to give it a twist to break the rubber free.
  5. Yx600 86
    Yx600 86 New Member
    London
    I now have one other unknown. There was an oil leak from this bolt. It just spins and the large thin nut behind it also turns but I can’t seem to remove it: Neither tighten. Any ideas, threads gone? Is it some sort of pressure relief?
  6. Toomanybikes
    Tsawwassen bc
    That is the main crank oil gallery !
    Should never be removed due to being commonly broken. If it fails oil everywhere. You may be able to install a metric drain plug repair bolt they are usually 1-2 mm oversized and locktite it in place
    XJ550H, Franz and Chitwood like this.
  7. XJ550H
