Photo of new fusebox install
Discussion in 'XJ Technical Chat' started by fjpish, Nov 16, 2008.
  1. fjpish
    fjpish New Member
    New Jersey
    I thought I would share this photo of my new fusebox install. This is the box from chacal (HCP378BC Replacement FUSEBOX). Old fuse box is removed, tool tray support is cut away to allow new fuse box to be mounted to airbox. There is still plenty of material left to support tray and the attached ingnitor. Spade tabs (barely visible) are angled towards front to allow existing wires (with new connectors) to reach. Only the four fuses to the left are used. The others are left in there as spares. No more glass fuses! Woohoo!
  2. artgostick
    artgostick New Member
    nice and clean install. well done.
  3. Zookie400
    Zookie400 Active Member
    Connecticut
    took the words right out of my mouth....looks factory, thumbs up!
  4. chacal
    Very nice!
  5. bill
    bill Active Member
    Raleigh, NC
    Great Job!
  6. bigfitz52
    Textbook. Thanks.
  7. shangovi
    shangovi Member
    Burtonsville MD
    Beautiful job! I will be doing the same soon might need a few pointers :D
  8. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Very Nice
  9. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Funny this post was brought up tonight as I was just about to post on how I spent this Sunday evening.
    I have owned the bike for 12+ years now and had always cringed when I looked at the fusebox mess the PO had left for me. The tangled mess never gave me any problems that I am aware of but I am happy I finally got around to cleaning it up a little.
    As you can see from the photos below the PO had spliced inline fuses into the harnes using "competition orange" wirenuts. Though they never gave me any trouble I was suprised at how much corrosion was under the wirenut on the main circuit.
    Shangovi when you begin plan NOT TO BE IN A HURRY, use a high quality pair of wire strippers/crimpers and most of all shrink tube is your best friend
  10. WiseManSage
    WiseManSage New Member
    Armidale, NSW, Australia
    Ive also done the same for my XJ. Help me with loads of problems i was having. Very nice install.
    Here are are few pic of my handy work....
  11. Polock
    :cry: i like my glass fuses :cry:
    i think they might be original
  12. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Polock. I double dog dare you to push on the clip ends that hold the fuses! If you do this, don't plan on going anywhere because they are very likely to break. The only time my bike has let me down is when a fuse clip broke 100 miles from home. I jammed the fuse into the bottom of the clip and made it home. I wired in 4 waterproof blade fuses and things have been fine ever since. It's not as pretty as those boxes that Chacal sells but I didn't know he had them at the time.
  13. MN-Maxims
    Saint Paul, MN
    Polock your lucky that those cheap clips Yamaha used have not broken yet. I just touched mine and they broke. You must have gotten the only good ones they made.
  14. MN-Maxims
    Saint Paul, MN
    SecaBob Nice work also. I just love the creative ideas you guys have here.
  15. yamaha4life
    yamaha4life Member
    OH---IO
    don't worry Polock i'm knocking on wood for you i need to upgrade also i have the same kind SecaRob had and are starting to get in the way
  16. Polock
    i know, i'll look at them before spring
    the sad part is i have a new fuse block on the bench, but i have a whole bunch of new glass fuses too
  17. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Thanks! Not sure how comfortable I am with the connectors sticking out like that. I'll probably fabricate something to cover them up
  18. wizard
    I used a food container lid.
  19. MN-Maxims
    Saint Paul, MN
    Awesome Wizard
  20. yamaha4life
    yamaha4life Member
    OH---IO
    Mr.Wizard...lol i call you Mr. out of respect 8) not sure if that pic makes your bike that much cleaner or me that much more hungry wish that would work on my 750 but would restrict air flow
