Rear wheel swap options for XJ750 (1981)
Discussion in 'XJ Technical Chat' started by Daniel Sinnott, May 15, 2018.
  1. Daniel Sinnott
    Daniel Sinnott New Member
    I have come across a cheap 81 XJ750 I am keen to customise, scrambler or bobber (most likely) is my current idea.
    I have a couple of front ends, one of which I will swap onto this (03 R6 or 1997 GSXR750) but they are both a tri-spoke alloy wheel.
    Is there another rear wheel from a later bike I can swap into this that will match (or at leats be close). I'm thinking a later XJ or FJ?? I understand that clearance will be an issue as there is little clearance on the standard tyre, so probably a 3.5 inch rim is going to be the limit!
    Any assistance appreciated.
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    The turbo guy fitted a diversion rear end and wheel, needed some narrowing at the bearing if I recall.
  3. Daniel Sinnott
    Any links to this build? Cant find anything from search or Google
  4. Minimutly
    West Wales, uk
  5. kerriskandiesinc
    NY
    Just saw a faceBook post where someone used an Xv535 rear Wheel.....(XV750 might fit too)
  6. XJ550H
    if you look hard enough you can find a few years of spoked virago rims to put on the bike very hard to find
  7. XJ550H
  8. Daniel Sinnott
    Thanks for the help - I'll check these out.
  9. kerriskandiesinc
    NY
    Not much info but...nice pics !! >
    Daniel Sinnott likes this.
