relocating choke
Discussion in 'XJ Modifications' started by cg82, Jun 28, 2013.
  1. cg82
    cg82 Member
    Rossland British Columbia
    Hey guys,
    has anybody relocated the choke? I am looking to go minimal on my handlebars and im trying to research ways to relocate the choke to down below the tank. anybody got any info on it?
  2. Ted
    Ted Member
    Sioux Falls, SD
    +1
    good question.. I've been wanting to do this too but haven't really found any good ideas or gotten around to it.
  3. MattsXJ
    MattsXJ New Member
    Florida
    I relocated mine below the seat without a problem. Still functions just fine.
  4. cg82
    cg82 Member
    where did you find the new cable and what mount did you use? did you just make one?
  5. MattsXJ
    MattsXJ New Member
    Florida
    The housing itself is held together by a screw in the middle. I ran the stock cable back and used a self tapper to relace the original screw. Ill see if I can get a picture for you. I have hardtailed my bike so mine is a little different.
    I was worried the stock cable might bind but surprisingly its been just fine.
  6. ArnoldH3
    ArnoldH3 New Member
    LA
    Any picture to go along with this? Lol
  7. ArnoldH3
    ArnoldH3 New Member
    LA
    No picture? I want to relocate the choke as well
  8. XJ550H
    there is a thread from a few years ago here the poster used a bicycle shift lever down on the motor
    if you can make a longer rod you can move the bracket on the carb hats to the left outer carb and the bracket on the rod on to the outside you can mount a
    bicycle shifter lever on the hat bracket with a short cable or linkage running to the rod bracket
    ArnoldH3 likes this.
  9. cds1984
    cds1984 Active Member
    Perth, Western Australia
    I Just recently shortened a cable after watching a you tube video on making a custom cable.
    I didn't follow the guys recipe as I don't have bullets lying around and I have flux in a plastic jar.
    I like his old-school methods haha, very nice.
    Have a look.
    Here is the link... makes you wonder why you didn't do it before once you do it once.
    I did use bronze, gas bottle torch and a piece of brass from a computer motherboard stand to make my end.
  10. desmotom
    desmotom Active Member
    Canada MB
    I'm working on this too at the moment, will post results when I'm done.
  11. XJ550H
  12. ArnoldH3
    ArnoldH3 New Member
    LA
    Definitely above my knowledge but I will research and attempt this. Seems like an excellent way to relocate it where it should be, near the carbs
  13. k-moe
  14. k-moe
    Makes Choke adjustment while riding on a cold morning a bit more difficult, but I can see the appeal to that location.
  15. XJ550H
    look at the rod on a 550 carb it is on the outside of the left carb
  16. ArnoldH3
    ArnoldH3 New Member
    LA
    Honestly I just want it away from the controls. Lol and most aftermarket set of controls and switches don't include it.
  17. francois maltais
    francois maltais New Member
    moncton
    Bike lever is soooo easy. 10$ for the lever. Bolt it right on the bracket that was originally used for the choke cable. Cut the wire and keep only the wire itself and wrap it around the lever. DONE
  18. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    These things too, mower repair shop. Make a little bracket, mount where you want and cut cable to length.
  19. XJ550H
    francois maltais likes this.
  20. Simmy
    The FZ600 has the enrichener lever right on the end of the carbs. Anyone trying to eliminate the cable and handlebar lever on the XJ550 should look for the FZ enrichener rod.
    I can't see why it wouldn't fit. I see the original poster was referring to the 650 which is another matter.
