Rubbers between cilinder fins
Discussion in 'XJ Technical Chat' started by Henkies, May 19, 2014.
  1. Henkies
    Henkies Member
    The Netherlands, Europe
    Hi,
    I've spraypainted the aircooled cilinder of my xj700s.
    There appeared to be wedge-shaped rubbers between the cooling fins everywhere. I suppose that serves a purpose, so where exactly should I put them back?
    Thanks!
  2. TIMEtoRIDE
    They go between every other fin (typically) pick the longest, deepest fins.
    Have a look at some pictures in the "gallery" for examples.
    The purpose is to quiet the ringing of the motor - to absorb noise.
  3. jesse8931
    jesse8931 Member
    ann arbor, mi
    Aircooled motors use the rubber so the fins do not vibrate and break.
    Actually TimetoRide is correct. Not all air cooled bikes have rubber dampeners between the fins. In fact most don't. Typically the high revving inline fours have them.
    Vacuum line is a suitable replacement.
  5. hogfiddles
    That is correct. They are there to dampen high frequency resonance.
    Dave f
  6. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Rubbers on your motorcycle....glad to see someone practicing "Safe Motorcycling" :roll: :roll:
  7. paul.hardy
    paul.hardy Member
    Tasmaina - Australia
    I blew mine out of the fins with a pressure washer a year or two ago and lost them did seem to make any difference to the noise of the motor and have not broken off any fins so far
  8. Henkies
    Henkies Member
    OK clear, Thanks everybody!
