Should I "un-de-tune" my Hitachi HSC32's?
Discussion in 'XJ Technical Chat' started by StahlMaster, Dec 25, 2018.
  1. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    Per this website... "That being said, all of these bikes were jetted a bit lean from the factory, in order to satisfy EPA emissions requirements of that era. So even a stock engine can benefit from slightly larger fuel jets...
    I have my carbs apart for major rebuild and I'm wondering what exactly I would need to replace to "un-de-tune" my Hitachi HSC32 from my 1982 XJ650J Maxim here in Michigan, USA.
    I've read to go from #110 to #112 on the main fuel jet and from #40 to #41 on the air jet. Is that all? Just the jets?
    D
    This is just a photo of Carb #1
    just the pilot jets. the pilot jet is what was being tested through the ports in the exhaust by the gas sniffer
  3. XJ550H
    check this site you could go with the Canadian specs
    http://xjbikes.wikidot.com/carb-specs
    Years & Models: 1982-3 XJ650 Maxim USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 5N800
    Main FUEL Jet Size: #110
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #50
    Pilot AIR Jet Size: #205
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-10
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
    Years & Models: 1982-4 XJ650 Maxim Canadian models
    Carb Series: HSC32
    Carb Model ID: 5N900 or 5U900
    Main FUEL Jet Size: #112
    Pilot FUEL Jet Size: #43
  4. StahlMaster
    Southgate, Michigan
    So I could go with:
    Main FUEL Jet Size: #112 (to replace stock #110)
    Pilot FUEL Jet Size: #43 (to replace stock #40)
  5. Jetfixer
    I upped jets in my 750 Seca ...main I put in a 124 ended up putting 120 back in , ran so much better and my fuel mileage was better .
  6. StahlMaster
    Southgate, Michigan
    Perhaps going from #120 to #124 was too much of a jump.
  7. Jetfixer
    The only other was 122 , honestly did not notice ANY. Difference in flat out speed .
  8. StahlMaster
    Southgate, Michigan
    I'm going to leave it stock. I really like to get the most MPG from these tiny tanks.
