Simmy's Naked Turbo Project
Discussion in 'XJ Modifications' started by Simmy, Feb 25, 2017.
  1. k-moe
    I think the paint scheme is fine as-is.
    Once the mixture is dialed in nobody will guess what she can do.
    kosel likes this.
  2. Simmy
    I just re-read what you wrote, and went back out to the garage. It does light up with the starter button, we're good.
    For some reason I thought it should glow as soon as the key is turned on.
    jayrodoh likes this.
  3. Simmy
    I have a silver tail and sidecovers so I could go the stock 650 look real easy.
    Only you most astute XJ guys would spot the Turbo exhaust pipes.
    However, I already have custom decals BDesigns.ca made for me.
    I've got a plan, secret for now.
  4. Dave in Ireland
    Ireland
    Love that turbo whistle.
  5. sybe
    sybe Active Member
    NYC - Brooklyn
    Love it. Nice work on getting it on the road
  6. Simmy
    Thanks for the comments guys, all appreciated. I haven't got any further with tuning the bike and have a total of 8 kilometers on it.
    I'm teaching my 15 yo son a few things so last night we took the head off the $75 XJ900 motor I have and I liked what I saw. The motor turned freely and the bores appear good.
    There was a rough line I found 1/2 way down the stroke where the piston was sitting but I was able to rub it away with my finger.
    I will need to measure the bores, pistons and ring gap more precisely but initial glance looks good.
    I have a $50 Turbo motor which I was told is seized and looks like it was stored in a swamp. That's ok as it's a mock up only.
    Step 1 is to set the the 900 pistons & barrels on to this 650T crank and cases (& head) to determine what the resultant compression ratio is.
    I anticipate having to machine the block to get the stock turbo 8.2:1 CR. This would be a 738 motor.
    Step 2 in this mock up is to swap in the 900 crank, rods, block & pistons into the Turbo cases & head.
    I anticipate this configuration would need the block raised to lower the CR to 8.2:1. This would obviously be an 853 motor.
    I'm leaning towards the 738 as it will not require splitting my cases and I can install it without removing the motor from the bike.
    I went through the following procedure with my 911X when I grafted FZR1000 barrels to the XJ750X.
    Smother the rings on #1 piston with grease before slipping the barrel on.
    Set the piston to TDC, install the head then fill the combustion chamber with a measured volume of WD40 to the spark plug hole.
    Now just compare the cc's of WD40 (combustion chamber) to the volume of the cylinder (bore area x stroke)
    I'll be posting these findings. I've noticed the Yamaha manuals show the various volumes of the heads and I think the standard 650 is different than the Turbo so these numbers might not be relevant to anything but a big bore turbo (8.2:1)
    If anyone is looking for 900 parts I will have lots available, the only parts I need are mentioned above.
    The cams look to be in great condition and will likely go in the trash if no one wants them.
    Same with the head although the intake and exhaust studs are all snapped off so it would be a challenge to salvage it.
    Cam cover is good if someone wants to refinish it while theirs is still on the bike.
    I also have 600 motor parts if someone wants them, otherwise going to the trash also.
  7. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    So, why are you doing this? Why not just turbo the 900 motor? Is it to do with the oil scavenge pump?
  8. Simmy
    This is what I believe would be required to swap in a 900:
    1. I believe the oil pump and oil pan from the Turbo can be swapped over to the 900. I'm not certain if the oil pump drive sprocket spins the pump same RPM's?
    2. Pick up coils from the Turbo could be moved over also, I see no problem there.
    3. The head from the Turbo needs to be utilized for the special Turbo cams and the Turbo's carbs. The 900 head is wider so the cams are not interchangeable nor the carbs.
    4. the knock sensor can be installed on the 900 barrels. The boss is there, just needs to be tapped.
    5. The compression still needs to be lowered (extra base gasket) and using the Turbo head means I still need to go through the actual fluid measurements.
    6. the 900 has an 8mm longer stroke so I suspect the carbs would be misaligned by 4mm. I think this backyard mechanic could make that fit.
    So you are correct @Minimutly it would be easiest to just swap in 95% of a good 900 motor. Unfortunately the one I have has no history and I don't know why it was parted.
    I know I bastardized this bike completely already but everything I've done I believe makes it more desirable than the OEM Turbo, gawd they are ugly.
    It is still a numbers matching bike for whatever that's worth, LOL.
    Having said this I've made an appointment tomorrow to go see a 900, see here - https://www.kijiji.ca/v-street-crui...-project-bike-with-ownership-900cc/1507653079
    It would be nice to keep my numbers matching motor completely stock on the shelf and abuse the shite out of another motor.
  9. Minimutly
    West Wales, uk
    Why not build a 900 turbo that looks like the seca? (Next project?) The frame is stronger and stiffer,I think you could add some diversion wheels, brakes and swingarm, it would be quick and pretty, and handle quite well? Maybe you should have started with a 900, but that's history.
  10. Simmy
    No I'm building exactly what I envisioned, no regrets.
    k-moe and jayrodoh like this.
  11. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    This exactly.
  12. Minimutly
    West Wales, uk
    And nor should you have any - what you've created is awesome - Yamaha should have done it.
    But wht faff around with a 900 engine - is the 650 not fast enough? I did think you were looking to build another, hence my comment. I have a 900 frame and engine, plus a 650 turbo engine - maybe will become a 900 turbo eventually, but need to collect all the other bits first. Diversion suspension and brakes on the list, but not sure about tank and seat - I don't much like the 900 ones, the maxim tank is tiny. Maybe a seca tank and seat would be the answer?
  13. Simmy
    Thanks @Minimutly I agree Yamaha I think was trying to showcase their faring technology which was apparently borrowed from their marine division.
    It was a complete miss as fiberglass fairings were replaced in 84 with modern plastics.
    I shaved a ton of weight.
    This is not a done deal by any means. I'm looking at more displacement to help the off boost situation. I have about 75,000 kms riding the original Turbo back in the 80's and it was a slug until the boost hit.
    Shaving all that weight will certainly help with the off boost response. It's more of a future project, I don't have a lot of room for all these extra motors kicking around so I'd like to get the parts sorted and cleared out.
    I'd like to have a 900 cylinder block & pistons in a box with the block painted and machined precisely to give me 8.2:1 CR. A direct bolt it in at anytime in the future.
    Obviously stuffing a 900 crank into the cases is a lot more work and why I'm leaning towards a 738. Coincidentally that is the same displacement of the Kawasaki Turbo.
    What I was alluding to earlier about a longer stroke misaligning things was the interference raising the carbs 4mm higher. Presently the larger turbo petcock mounted on the 650RJ tank just fits in there.
    That 4mm would keep the tank from fitting into position.
    The easiest approach is to use the Turbo frame as it accommodates the mounting of the turbo down between the centre stand pedestals, they are more widely spaced to allow for it.
    Another frame will require a lot more work to make the stock Yamaha turbo stuff fit. Frankly, when I look at the 900 frame it is really no different than the other XJ's unless the tubing is perhaps thicker.
    Sounds interesting. Over here in US and Canada we never got the 900 Diversion so no cheap parts to play with.
    I actually rented one in Norway one vacation. Put about 5,000 kms on it, great bike.
  14. Simmy
    67mm barrels from the 900.
    It needs to be shortened to fit the 52.4 stroke, then honed and maybe new rings.
    Tapped for the knock sensor and painted shiny black of course.
    this is the scrapped XJ650Turbo motor I have.
    I've named it swamprat.
    Swamprat is just a bench motor to determine how much to shorten that 900 block.
    I didn't even bother to try turning this. Its soaking now with pure acetone.
    I need these barrels and pistons off
    Stripping down swamp rat and the 900 restocked my shim inventory.
    I'm ready for anything between 260 and 290.
  15. Simmy
    knock sensor has tapered threads, I need to find the right tap
  16. k-moe
    Yay for using a pipe tread. Good sealing; no gasket needed.
  17. Minimutly
    West Wales, uk
    Hmmm, forged pistons...
    Re the jugs from the 900, are you sure the "holes" in the 650 cases will let them in?
    Surely nothing to seal around the knock sensor? It's all about hard mounting isn't it?
  18. Simmy
    I need to free the block from Swamprat to find out.
    Aluminum stands no chance against me and my die grinder, LOL.
  19. k-moe
    +1 A common "adjustment" in the scootering world.
  20. Minimutly
    West Wales, uk
    My neghbour used to race a steel framed, twin thunderrace engined autograss special, with sleeved and overbored jugs (and upgraded cams). He blew one, was going to fit the overbored top end on a standard case, and asked me to die grind the case to make it fit. What about the swarf - you'll need to strip it says I. No way no time, no skill etc etc.
    So I suffed it with greased up rags, and attacked it, with advise to "hang it upside down from a loader, stick the pressure washer lance in and let go", then paraffin wash and build it quick.
    It worked fine, but it was his risk.
