Specfx 900
Discussion in 'Hangout Lounge' started by Jarich, Aug 31, 2026.
  1. Jarich
    Jarich Member
    Ontario Canada
    Saturday night to Monday morning progress on project 750/900. Will be tagged as
    special fx900.
    PXL_20260829_142055555.jpg PXL_20260831_115820995.PORTRAIT.jpg Front end almost ready to install. Safety inspection on the 8th.
    Fuller56 likes this.
  2. Jarich
    Jarich Member
    Ontario Canada
  3. Fuller56
    Fuller56 Well-Known Member
    So far, so good! Good luck, we will be watching and wishing you well. I do like those Diversion fairings.....
    Jarich likes this.
  4. Jarich
    Jarich Member
    Ontario Canada
    y
    Thanks. This is based on an 84 xj750rl in Canada. We call those fj600 fairings here.
    The rest is 83 900 engine, 86 fj600 bodywork, fz750 forks, fzr400 fr wheel and diversion rear wheel.
  5. Jarich
    Jarich Member
    Ontario Canada
    Engine slid in peacefully on new cradle lift recently welded up. Makes it an easy one man job. Better pics of it won't load right now
  6. Jarich
    Jarich Member
    Ontario Canada
    Screenshot_20260902-073320~2.jpg Screenshot_20260902-073351~2.jpg Screenshot_20260902-073320~2.jpg Screenshot_20260902-073320~2.jpg Screenshot_20260902-073351~2.jpg
    co.dirtbiker likes this.
  7. Jarich
    Jarich Member
    Ontario Canada
    Some good progress today
    Exhaust welded up and installed
    Cables sorted. Brake hoses being developed. Or robbed from other units.
    Gets a test drive soon hopefully
  8. Fuller56
    @Jarich, that engine cradle is slick! Could we impose on you for info or pics of how you attach it to the engine? Or is it attach the engine to it.....
    Jarich likes this.
  9. Jarich
    Jarich Member
    Ontario Canada
    That is something my 63-year-old back wishes I thought of 40 years ago. I bolt onto the intake manifolds with two of these brackets and slide the c-shaped cradle into them. These were drilled for the 550/600 head and were just being drilled to bolt to the 900 head.
    The top mount slides sideways to allow perfect level.
    Once I have it on a sliding beam it will be the easiest one man engine install system.
    The cradle is from an old exercise machine and it was exactly the shape when I went looking for something like this. But it could be easily duplicated. Even if you put a bar across the top and had a guy on either side lifting it would still be very easy.
    We didn't even so much as bump the frame putting in the engine.
  10. Fuller56
    Very cool rig. Thank you for the pics.
  11. Jarich
    Jarich Member
    Ontario Canada
    No problem and thanks for the interest. I have better pictures but have trouble with loading some. Everything's from the same camera but probably 30 or 40% of my pictures say an error occurred
    I switched longer rear shocks and drop the front and think it really improved the stance
  12. Jarich
    Jarich Member
    Ontario Canada
    When is a pod filter not a pod filter. Stock 900 airbox was modified to accept a Weber style air filter. It all fits neatly under seat and can be easily serviced in place. With the stock mufflers on the bike I expect to hear a fair bit of air noise under there. Like flipping the lid of an old Chevy air cleaner
  13. Jarich
    Jarich Member
    Ontario Canada
    It's officially a certified road unit.
  14. Fuller56
    Congrats on your official certification. Well done. Your air box mod looks very interesting but how is that going to work in the rain? How is it running or have you not had a chance to test it yet?
  15. Jarich
    Jarich Member
    Ontario Canada
    Thanks. Places are busy around here so I had to book that two and a half weeks ago. So the pressure was on
    I've got about 20K on it so far and as fast as about 100Kph only. But I haven't noticed a single glitch in the jetting app. I put it all back to stock to start and expected some but needles and low speed are certainly happy.
    I'm kind of a veteran of the pod wars and fall on the side of you can in fact make them work. This is like a more protected version of that to me. There could be some ducting Incorporated later to make it draw from under the seat but it's fine so far. If you look at the stock 750 900 airbox it's heavily restricted / biased to the right side. Hard to get flow to the other side. Especially with the long snorkels of the 750. This is kind of my way of addressing that problem.
    The chassis is working really nice. It'll probably get a top clamp kit to put handlebars on for next year. Just a little more comfortable angle than these clip-ons can do
  16. Simmy
    Hello @Jarich
    We're you at the Grand Bend Festival of Speed last year?
    I spoke with someone from the 550 Seca race camp then, was that you?
    I was on track with my KTM supermotard.
    Jarich likes this.
  17. Jarich
    Jarich Member
    Ontario Canada
    That was great event and we had the pair of 550s there. I ripped around on IMG_20260909_172658.jpg the Seca Beast all weekend
  18. Simmy
    Jarich likes this.
  19. Simmy
    I must say your 550 Seca racers are very cool. Loved seeing them on the track. The Frankenstein 550 above is crazy
    Jarich likes this.
  20. Simmy
    Can you tell us about your race motors?
    Carbs, crank, pistons, cams -displacement
    Mods?
    Jarich likes this.
  21. Jarich
    Jarich Member
    Ontario Canada
    Thanks for that. We have a fair bit of time into the pair of 550s and they are working really well now. I am struggling to get ready for a trip so not sure how much time I spend right now but I will do a bit of a run down on them
    The teaser is 84rwhp out of the 705 which is now a 740 and waiting for it's first run.
    Timbox, Fuller56 and Simmy like this.
  22. Simmy
    wow, 65mm bore
    Jarich likes this.
  23. Jarich
    Jarich Member
    Ontario Canada
    The perfect size for no one to make a head gasket it turns out so that's a handmade .030 copper gasket.
    The external oil routing to cams is new and untested yet beyond pre pumping of the system. Really wanted to get away from the factory O-rings. Too much trouble when you start decking surfaces extreme amounts
  24. Jarich
    Jarich Member
    Ontario Canada
    This is the 3rd generation of the Seca 550 vintage race bikes we have developed over the last 6 seasons.
    Taking what we learned on 1 and 2 we went right to fzr400 rear arm, yss shocks on the rear paired to shortened, yzf 600 front end w 3.5 x 17 wheel but with adapters to run the class legal 2 piston calipers. Fit to the larger discs and with good pads it's actually impressive how good the brakes are. Rear wheel is 4.5x17 GSXR/sv650.
    It had a fzr rear seat for a couple of years but was updated to a really nice original tail and seat we found.
    Frame is braced in a few spots and fj600 sections sneak in a few spots(swingarm pivot) and all extra tabs removed
    Both frames have removable chromoly sections connecting fr and rear of top of frame
    Timbox and Fuller56 like this.
