Speed at a given RPM for the maxim 650
Discussion in 'XJ Technical Chat' started by woot, Aug 17, 2006.
  1. woot
    woot Active Member
    I've been playing with gear ratios with the CBR. While I was at it I made up a spreadsheet for RPM, hp, torque and speed... I don't have a dyno of a maxim at hand, but I figured I'd post what I had.
    This is the jpeg version, xls version available to all who are interested. This is not hand calculated - I've written little formulas up so that you can see what changing a gear ratio or a tire size would do to speed at a given rpm...
    The tire circ is a rough estimate, if someone has an actual measurement it would be better to use that... it could lead to a few percentage change in speed.
    Also I've used km/h... easy enough to switch it to mph.
