Throtte Shaft Seals a necessity to change?
Discussion in 'XJ Technical Chat' started by arniepyeinthesky, Nov 27, 2017.
  1. arniepyeinthesky
    arniepyeinthesky New Member
    Toronto
    Makes sense. There's 3 idle holes on the carbs though, half cover the middle one.
    Carb # 3 is the master. So first set that before setting others. What's the order if them again?
    When I tried starting it last, both holes were uncovered at idle.
    Will try this, see what difference it makes, and update.
  2. hogfiddles
    For bench sync, I open til the middle hole on #3 is totally uncovered. (that way they are all open far enough that a different butterfly won't hold anything open or close too soon). Now ai adjust the remaining three to match. Doesn't matter what order. Once all match, I back the idle screw out til butterfly 3 covers half of the middle hole. Fine adjust the remaking three to match. Order doesn't matter. I snap them open a shut a few times, then check. Adjust if needed. install. Start up and do running sync.
    My preferred order -
    1. Balance 4 to 3
    2. Balance 1 and 2
    3. Balance 1/2 to 3/4
  3. Minimutly
    Minimutly Active Member
    West Wales, uk
    Priceless info, and so simple. It works too, better than a bodged running sync.
    k-moe Pie, Bacon, Burbon. Moderator Premium Member
    The Great American Desert
    There is one idle hole (the one closest to the slide, also the one the the idle mixture screw controls), one transition hole (the middle one), and one enrichment hole (the one furthest from the slide, which also acts as a transition hole).
  5. Minimutly
    West Wales, uk
    There you are, good explanation, and really, you should be able to see which order to adjust them - just work outwards from the master.
