torque question
Discussion in 'XJ Technical Chat' started by ifonly2005, Jul 19, 2012.
  1. ifonly2005
    ifonly2005 Member
    exeter nh
    i got a few things coming from chacal this weekend hopefully, in wich one is a new oil pan gasket. question: does anyone think 10 ft/lbs is ok to torque to? i know the valve cover gasket calls for 7,so im assuming so would the pan???? but 10s the lowest i go.... and although some of you might say tighten with pinky... im not like that:) i like to torque... so having a torque stick would greatly reduce myself for having to buy more stuff. please and thanks :)
  2. MiCarl
    You need another torque wrench.
  3. ifonly2005
    ifonly2005 Member
    exeter nh
    lol.... i havent bought one yet for lower applications... but the stores only sell them starting at 10 ft/lbs. i just dont really see 3 ft lbs being crucial!?
  4. mtnbikecrazy55
    Harbor freight torque wrenches are cheap. And work better than guessing. They go on sale for 10-12 bucks each from time to time. Get a 1/4", 3/4", and 1/2" so you're set. You can always convert inch lbs to ft lbs as well.
  5. Polock
    when one of those 6mm bolts lets go and you get that sick feeling that makes you want to dirty your shorts you'll wish you had one
  6. ifonly2005
    ifonly2005 Member
    exeter nh
    No I'm going to get one.. my question was do you think if it said 7.. that 10 would be ok
  7. mlew
    mlew Well-Known Member
    Apex, NC
    Don't risk pulling the threads out, spend 10$ on the right tool. 10 would be too much.
  8. Polock
    those things are meant to be accurate mid scale, at the bottom like that you may only get 5, who knows. i set my 1/4 inch one at 6 to do a 7 you can always tighten them a little more
  9. Recoil87
    Recoil87 Member
    Diamond Bar, CA
    yup I agree with Polock man...just go buy a 10$ wrench man...its worth it and youll have it when ever you need it again...just stick it in your tool box and forget about it until you need it...
  10. ifonly2005
    ifonly2005 Member
    exeter nh
    I hear ya. Ill ask around to borrow one.kind of don't want to wait 2 weeks for a tool. So no one corrected me... so I assume oil pans 7 ftLbs as well??
  11. bigfitz52
    7.2 ft/lb is correct.
    And I agree that you need a smaller torque wrench. I would recommend a "micrometer" type with a 25~250 INCH/pound range.
