Valve cover bolt torque.
Discussion in 'XJ Technical Chat' started by Marc browning, Jul 18, 2018.
  1. Marc browning
    Marc browning Member
    Wichita, kansas
    Xj550 maxim, I can find this torque in my clymer manual. They are a shoulder bolt so I knot the torque is low.
  2. turpentyne
    turpentyne Active Member
    Desert SW
    If I recall, 7 pounds, all around.
    Colin 85 700 and k-moe like this.
  3. k-moe
    7.2 ft lb and no tighter.
    Colin 85 700 likes this.
  4. Marc browning
    Wichita, kansas
    Thanks, sounds high, I was thinking more like 4 lb. But I'll do 7.
  5. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Correct,7 lb/ft or 82 in/lb
  6. Colin 85 700
    Thunder Bay, ON
    All 6mmx1mm bolts are nominal torqued to 7lb/ft, in structural areas, 8 lb/ft
    All 8 mmx1.25 mm bolts are 18-20 ft lb, structural areas 20-22 lb/ft
    All 10mmx1.5 mm bolts are 26-28ft/lbs, structural 28-30 lb/ft
    All 10mmx1.25mm bolts are 27-29ft/lbs, structural30- 32lb/ft
    Generally torqued only...... Exceptions apply
    Fork triple clamps, 8mmx1.25 16-18ft/lb, no more! Yet structural.... Consult a Manual!
  7. k-moe
    You could also consult a Manũel. He knows stuff.
  8. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Do you also measure things with a venereal clapper?
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Um, venereal clap? Sounds like something to avoid.:eek:
  10. Chitwood
    I was wondering if you'd comment Matti. It's a play on vernier caliper, but yes, avoid the venereal clap
  11. k-moe
    I don't see how this is a constructive comment (not that my last comment was either).
    Overtightening of the valve cover bolts on YICS engines has been known to crack the head.
    it's a common enough problem that we try to help people avoid that.
  12. Chitwood
    Agreed. I apologize.
  13. Plug
    Plug Active Member
    Missouri
    And gain valuable experience in installing helicoils.......lesson learned
  14. Marc browning
    Wichita, kansas
    Thanks for the help, getting the bike back together.
