  1. Wayne Stuart-Cole
    Wayne Stuart-Cole Member
    liverpool
    Finally got the carbs in (Saturday) assembled everything, added fuel, ignition and choke on.... battery turned the starter a couple of times........ then died.
  2. kerriskandiesinc
    NY
    Use your car battery.......just for that initial 'clean start'....
  3. Jetfixer
    Put bike away for winter:( , cleaned up garage so I can get truck and wifes car in . Rebuilt starter while I was at it . Sad I did not ride as much as I wanted to had so much happen that kept me from doing so I figure I only rode about 700 miles .
  4. Franz
    700 miles more than me Jetfixer my bike is in bits, hopefully it will be on the road in 2020. All the best.
    Jetfixer likes this.
  5. Rusty81
    Rusty81 Member
    Sarnia On, Canada
    Bought a used 1985 XJ700 last week. Didn’t run when I got it so that’s my winter project. Had it sputtering the other day but wouldn’t catch.
    Yesterday I changed the fuse for the neutral light so it lights up now. Lots more to do still...
  6. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Dialed carbs 1 3 and 4 again while test riding around the house. Looks like I am going to have to pull the tank again to get #2 a little richer. Also got the LED headlamp in. Fits well, the voltage noise is going to have to get addressed. The headlight strobing has to stop. Got a plan and a 10A DC-DC rectifier to fix it.
    Rusty81 likes this.
  7. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    Dig it.
    Rusty81 likes this.
  8. Pizzaman
    Pizzaman Member
    north Seattle
    installed a new fuse box from a kit from Len at XJ4ever. Beautiful kit with great instructions included. Took a few hours because my soldering skills are weak. Maybe I should have just used the crimp connections provided but I wanted to learn a new skill.
  9. kerriskandiesinc
    NY
    Changed the engine oil...in the RJ....already done the other Seca, using Yamalube, in both...
    I DO need to find a proper copper 'crush' washer x2 soon, I can't stand the aluminum ones
    Didn't do the filters.....I usually do those every other change ...and there was very little 'swarf' on either of my magnets
    EDIT: my one throttle cable feels 'sticky'.....thoughts.....? Almost feels like its struggling to return/snap......I checked its 'run', its seems fine, and the return springs in the carbs feel 'tight'...
    I never know WHAT, if anything to lube 80's cables with..are these ones nylon, like newer Jap bikes?? ( can't remember)
  10. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    Same here, but I can only fit one car in now.
  11. Wayne Stuart-Cole
    liverpool
    Only got the not run for 2 1/2 years xj running......... :)
  12. kerriskandiesinc
    NY
    Top banana!!
    These bikes are unburstable, undefeatable.....lol PS PLEASE check that bevel breather with an expert ( preferably Dave...Hogfiddles) before you take a long ride !!!
  13. Wayne Stuart-Cole
    liverpool
    Going nowhere for a while, clutch cable is cream crackered and for some strange reason I own absolutely NO motorcycle gear whatsoever
    kerriskandiesinc likes this.
  14. kerriskandiesinc
    NY
    Wouldn't be a massive problem...over 'ere, safety gear..or even a leather is rarely seen (even lids are optional..depending on the State!).......mind you, 95 degreee plus summers, don't help, although at the moment we are at a negative 5 or 10 degrees tonight, thanks to an arctic blast !!
  15. McTavish
    Daytona Beach, Fla.
    Cleaned ignition switch contacts today. problem was intermittent taillight. jostling the key [while running] light on, let go, light off.
    seems to have solved the issue. time will tell.
  16. Ryengoth
    Wilmington, NC
    Did you put a little bulb grease/silicone grease on the contact plates?
  17. McTavish
    Daytona Beach, Fla.
  18. Ryengoth
    Wilmington, NC
    They're brass/copper contacts so it does help with wear. Maybe next time. :D
  19. McTavish
    Daytona Beach, Fla.
    1o minutes to remove ign.sw. 10 min. clean, 10 min. reassembly.
    on another note, when I was done, headlight didn't work, traced it down [with meter] too the h4 bulb desiding to go bad at this particular time.
    $8 at nappa, - back on the road.
    Ryengoth likes this.
  20. Ryengoth
    Wilmington, NC
    H4 LED conversion and avoid the halogen random burnout
