  1. XJcook
    XJcook New Member
    Raleigh, NC
    I replaced the rubber on my foot pegs this weekend - new rubber purchased from XJ4ever.
    They look awesome. Ever time I look at them, I smile.
    Jetfixer likes this.
    just dont look at them when your rolling down the road;)
    milforal, Jetfixer and hogfiddles like this.
  3. Jetfixer
    Spent day working on Johnny Cash bike , sad day put old Yellow away for winter . Put battery on charger love the AMG battery my spare I'm going to use in other bike I had under work bench , had not touched in six months was still at 12 volts my smart charger had it at 12.9 in 10 minutes.
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Another couple of hours rebuilding and setting the choke linkages on my vmax mikunis, bench set the throttles, refitted the drain tubes, only throttle cables to refit and they're ready to go back on and go for a spin.:)
    Got my xj600 diversion front forks back (the Jack Daniels ebay ones). They're 41mm, short, and the xjr 1200 wheel fits between them, but allas the axle is bigger than the wheelbearings. Hmmm, I did cross check the part numbers, something went wrong there then...
  5. XJ550H
    all balls racing has a cross referance to correct that
  6. Minimutly
    West Wales, uk
    Thanks for that, will try a search on their site.
  7. seph2004
    seph2004 New Member
    Andover, MN
    So around 5 years ago around this time, I acquired my 80 XJ650G. I paid 100 for the whole bike which included a WindJammer and Luggage box. The guy didn't have a title on it, so I had him sign a Bill of Sale and the Lost Title paperwork since he bought the bike as a parts bike. I brought it home and performed some diagnosis and discovered the brass cylinder sleeve in cylinder 2 was disintegrated and pieces were everywhere. I tore the whole engine down, and then it sat for 4 1/2 years. I piddled with it for the last 6 months, and now with COVID-19, I picked up the project again and made some major progress. 3 weeks ago, I bled the front brake, installed my TPM system, and did some other odds and ends. Last week I reassembled the entire crankcase and got it ready to get the cylinder jug and head installed. Tonight, I installed the lower half of the engine in the frame and I will install the cylinder jugs and the cylinder head while it is in the frame (I took the engine apart out the frame when I pulled the engine apart). I also got the clutch cable attached, readjusted the pressure plate, and tested out the clutch adjustment. I have an upper gasket kit coming from France, which includes the head gaskets and everything else I will need. I should be able to finish the bike by Christmas!
    Franz and Jetfixer like this.
  8. dkavanagh
    Rochester, NY
    Yesterday, but close enough:
    Huntchuks and Jetfixer like this.
  9. hogfiddles
    Jealous
  10. dkavanagh
    Rochester, NY
    @hogfiddles how's your 550 seca project coming? Do you have all the parts now?
  11. hogfiddles
    I m hoping to move things around for the winter and maybe get that one inside to work on. Not sure what I still need right now
  12. Yammaat
    Yammaat Active Member
    Netherlands
    Told the SecaRat she will get an oilfilter conversionkit next year.
    She seems happy with that message because she hates that fiddling and messing with her lower pipes :oops:
  13. Minimutly
    West Wales, uk
    Took the vmax outnfor a spin after the carb repair/rebuild. Excellent.
    Yammaat and Franz like this.
  14. Yammaat
    Netherlands
    Got the battery out and rewrapped the sidepanels.
  15. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    Just put new shocks on the Seca 650 - got them from XJ4ever & they look brilliant. The RH shock (not installed in the photo) is fixed to the swingarm via a bolt whereas the other fixings are studs with dome nuts. I sourced a long M10 1.25 bolt, cut it down and installed a dome nut so they all match. This weekend the carbs get stripped for vapour blasting.
    Maybe instead of pulling the carbs apart I should clean the garage!
      File size:
      318.5 KB
    Jetfixer and Franz like this.
  16. Minimutly
    West Wales, uk
    Nice paint finish on the engine - what did you use?
  17. hogfiddles
    That is correct..... the bottom of the right side shock is bolted on through the bracket welded on the swingarm.
  18. Brent NZ
    I'm note sure on the brand, but it's a professionally-applied 2 pack paint. Rocker covers were vapour blasted, cylinder heads stripped and lightly sandblasted with the rest of the engine being hand-prepped before painting.
  19. Minimutly
    West Wales, uk
    Had a look at this today, the bearing in the xj1200 wheel is 42mm od, the diversion 600 and 900 is 50mm od.
    The allballs site has a crossmatch to 44mm, the nearest. So I probably could machine the wheel to fit this bearing, second option would be to fit a 900 or non abs xj1200 wheel.
    Had a minute or two to think about this, will get an xj900 wheel I think..
  20. CavScout
    CavScout New Member
    Tonawanda NY
    Started my (new to me) 550 Seca after it's sat for 10 years! That was enough to pull the front wheel to get the new tire put on (found a 90/90-19 at Chaparral) as well as an AGM battery black Friday deal that worked out well.
