  1. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    How do you get the silver tank? Looks good
    Noahsxj likes this.
  2. Noahsxj
    Noahsxj Active Member
    SW Missouri
    @Minimutly thanks! Just polished metal, I like it alot! Just a lot of upkeep
    Minimutly likes this.
  3. Noahsxj
    SW Missouri
    Ultrasonic cleaned and rebuilt some calipers
    The black one is for my virago, apparently it’s the same as the xj650/750’s?
    red one is a xj550 right side caliper. is color matched to the left side one that’s on my bike right now. FDE14E62-9AF1-4A93-8777-2A8C433F3D12.jpeg EAD047D0-AE5F-47BD-947B-562FEA811467.jpeg CA74DC8A-7B31-4BED-B8A3-0EC653DDC0C1.jpeg
  4. Jetfixer
    Hooked up charger to both bikes , only took 10 minutes for full charge .love the AMG battery temp is 22 degrees , had not started bikes since November, moved to pri set choke cranked a few times both fired right up , let them run till valve cover was hot to the touch . Counting the days till spring there is ice and snow out now here .
  5. Dan Gardner
    Minneapolis, MN
    I received a present from Santa @chacal yesterday.
  6. Litaos
    Litaos New Member
    Argentina
    Hola a todos. Soy nuevo aquí. Después de varios años, decidí reconstruir mi viejo xj 750 82 con 35000 millas. Se mantuvo durante 20 años. Lo primero que hice fue leer este sitio durante muchas horas y debo felicitarlos porque la información que obtuve es invaluable. Gracias por eso. Hoy Desmonte los frenos delanteros y traseros para examinarlos. Saludos
  7. Noahsxj
    SW Missouri
    @Litaos
    Oye hombre, cuentanos que ayuda necesitas!
    Litaos likes this.
  8. Minimutly
    West Wales, uk
    Do you speak Welsh? If so we could have a conversation, unlikely anyone else would understand.
    Otherwise it's English here I'm afraid.
    Litaos likes this.
  9. Minimutly
    West Wales, uk
    Needed to get at my mig welder, so started the vmax, took that outside, swapped batteries from the seca to the 650 maxim with the mikuni carbs, did my welding outside and put everything away. it was dark, but rude not to take the maxim for a spin. Cold but lovely...
    jsngrimm likes this.
  10. Dan Gardner
    Minneapolis, MN
    Another winter project done. XJ650J forks done. Ready for another 40 years!!!
    Also, for posterity, a shot of the janky system I used to compress the springs to put in the snap ring:
  11. Litaos
    Litaos New Member
    Argentina
    ¡¡Gracias por preguntar!! En unos días tendré muchas preguntas!! Hoy comencé con la reconstrucción del filtro de aire. Desafortunadamente, no es posible aquí.
    Dave in Ireland likes this.
  12. Litaos
    Litaos New Member
    Argentina
    Hola, gracias por responder. No hablo galés, intentaré que mi inglés sea más fluido.
    ¡¡Salud!!
  13. Minimutly
    West Wales, uk
    Hi, thanks for answering, I don't speak Welsh... Without googling the last sentence I'm lost??
    Litaos likes this.
  14. BigTex
    BigTex Member
    Northern Colorado
    Joining the cool kids.
  15. Dan Gardner
    Minneapolis, MN
    Another winter project done!! XJ650J caliper and master cylinder rebuilt and ready to be installed later with new lines later this spring!! FBE99594-B15B-4F19-BD6D-60E5F7227BD5.jpeg
    Litaos, StarGeneral and Jetfixer like this.
  16. amiel1157
    amiel1157 Member
    Philippines
    attempted to sychronized my carbs... hoping to find time to test ride, to many chores lined up
  17. StorminNorman
    StorminNorman Member
    Virginia
    Este foro ha sido genial para ayudarme a arreglar mi motocicleta. Hay mucha gente servicial aquí. Buena suerte con tu moto!
    Litaos likes this.
  18. StorminNorman
    Virginia
    Got some new progressive shocks staring at me every time I walk into the garage. Once the temps get into the 20s again, I'll go out and swap the old OEM shocks out.
    Uxbridge Brule likes this.
  19. Scott I
    Scott I Member
    wisconsin dells
    I'm there with you. Don't like doing mechanical work when it drops in the low teens and lower. No heated garage here.
    Jetfixer likes this.
  20. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    my re cleaning the carbs was a success.
    I humbly put my name on the list of those that should have done it right the first time. and I know better - not.
    I wasn't using a filter on fuel line when wet setting the first time.- probable cause.
