Wire Wheels and a 150 Rear - Virago 700 style!!
Discussion in 'XJ Modifications' started by MiGhost, Sep 19, 2011.
  1. coxbow
    coxbow Member
    Brussels, Belgium
  2. coxbow
    coxbow Member
    Brussels, Belgium
    I agree, but the 750 and 920/1000/1100 came only with alloy wheels, not a single spoke model, except the 535 and smaller, but that`s not plug&play...
  3. Eurotas
    Eurotas Member
    Edmonton
    Anybody know if MiGhost is still kickin it around here?
    His last post was Jan. 6, 2015. Hasn't been on since.
  5. Eurotas
    Eurotas Member
    Edmonton
    Well I found a wheel....except I'm not 100% if it's a match.
    http://m.ebay.com/itm/162075498168
  6. k-moe
    The seller is correct about that being the only spoked rear to ever be offered on a Virago 700/750.
    Look into spoked rear conversions first though. There used to be a place that made a kit for a spoked-hub rear for the Virago, but you had to lace it. Unfortunately I don't remember what shop it was.
    The 700ss wheel is 140/90-15, so it might fit depending on which XJ you want to put it on. The only issue would be tire rub at the swingarm.
  7. hogfiddles
    He's around.... Just incredibly busy. I talk with him occasionally-- last was about a month ago. I should call and say hi
  8. Eurotas
    Eurotas Member
    Edmonton
    I've looked around everywhere, and it seems that it's a pretty rare thing to do, so there's not much info. And any info I do find isn't 100% certain. That's why I wanted to have a chat with MiGhost and see what he has to say.
  9. Eurotas
    Eurotas Member
    Edmonton
    Yeah would you mind giving him a buzz and ask him if he could help me out with a few things?
  10. hogfiddles
    Euro---I just sent you a private conversation.....check your inbox
    Dave f
  11. Eurotas
    Eurotas Member
    Edmonton
    Also that wheel is a tad small....I was hoping to stay around the 18 inch size....
  12. MiGhost
    MiGhost Well-Known Member
    Sorry about not being around much. Life in all is gory!!
    About that wheel.
    That is the correct rear wheel, But that price is ridiculous!!
  13. Eurotas
    Eurotas Member
    Edmonton
    Ok so even if I were to buy this wheel, a 15 inch wheel wouldn't look silly with a 19 inch front wheel? What sizes do those virago wheels come in?
  14. MiGhost
    The stock virago wheels are 15" rear, 19" front.
    You can always relace a bigger rim on the hub if you needed to.
  15. Eurotas
    Eurotas Member
    Edmonton
    So I'm a little confused, I can use any rim but I have to keep the hub?
  16. k-moe
    The sidewall height of the rear tire makes it not look funny.
  17. k-moe
    Yes, basically. You'll need new spokes too. Earlier I mentioned conversion kits. Those (are or used to be) were essentially a custom machined hub (either a donor hub cut from a cast wheel, or a brand-new hub) along with spokes and a rim.
  18. Eurotas
    Eurotas Member
    Edmonton
    Ok, so what kid of dimensions do I have to work with? I don't know the exact size in the swing arm to accommodate that wheel if I were to choose it.
  19. k-moe
    That depends on which XJ you're fitting it to.
  20. MiGhost
    The XJ750R seca wheel is an 18", and will directly bolt into the 650/750 swing arm.
    You can lace an 18" rim onto the xv700 hub for the rear, but you will need to watch the tire sizing. 120/90-18 I believe is the max.
