Xj550 chain and sprocket replacement
Discussion in 'XJ DIY How-To Instructions' started by Jason1909, Jun 25, 2019.
  1. Jason1909
    Jason1909 New Member
    Spokane Washington
    Hey guys! I can't seem to find any threads or help online about replacing the chain and sprockets on my 81 xj550. I'm gonna go ahead and try it out later tonight but any help I could get would be much appreciated.
    you will have to losten or remove foot peg. mark the shift lever and shaft for reassembly. remove shifter cover.
    the front sprocket is held on by a plate with 2 bolts use Loctite med strength when reassembling.
    clean out the sprocket cavity. rear tire unbend tabs on brackets under bolts so you can reuse them also use med strength Loctite.
    clean chain before installing wd 40 works. if standard chain soak in oil overnight. if x or o ring chain lube with quality chain lube.
    Toomanybikes likes this.
  3. Toomanybikes
    Tsawwassen bc
    No further info required thanks to @XJ550H ’s good directions.
  4. XJ550H
    next question is chain adjustment I use an old folding carpenters ruler so I can adjust the angle and a caliper to measure from back side of adjuster to rear of swing arm on both sides.new cotter pin EVERY time
    adjust to 35mm 1.4 inches
  5. k-moe
    A chore that I don't miss.
    XJ550H likes this.
  6. XJ550H
    its a pain to do it but keeping chain well lubed cuts down how often you have to adjust it
  7. k-moe
    Same for driveshafts.
