Xj550 maxim neutral light
Discussion in 'XJ Technical Chat' started by Jenko, Mar 9, 2020.
  1. Jenko
    Jenko New Member
    Somerset uk
    Hi all. New uk member here. Got a 550 maxim looking very tidy.
    I have an issue with the neutral light on all the time. Checked all switches ok but still on. Any ideas appreciated.
  2. Toomanybikes
    Tsawwassen bc
    Sounds like the sending unit is stuck
  3. Franz
    The pin on my neutral switch was seized.
  4. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    It is very easy to pinch the neutral wire under the chain cover. Been there done that.
  5. Jenko
    Jenko New Member
    Somerset uk
    Hi thanks. Ive disconnected the neutral switch. Clutch switch and side stand switch. Checked cables and still it shines bright!! Mmmm.
  6. XJ550H
    the s/b sky blue wire runs to neutral switch and to diode block as well as the starter circuit cut off relay then to clutch safety switch.
    bad clutch safety switch could be a problem or the sb wire running up back of motor could be shorting
    bad diode block
    check to make sure you have correct relay plugged in to the connector for the starter circuit cut off relay.
  7. Jenko
    Jenko New Member
    Somerset uk
    Many thanks. Its the diode block. Managed to get apart and replace diode and its now going off. Yippee now ready to roll. Cheers.
  8. VinceD67
    VinceD67 New Member
    Ottawa, On
    Hi do you have a picture of both sides of the connectors for the Diode block? I have an 81-83 XJ550 and only 5 wires. All the ones I’ve seen posted have 6-8 wires
    much appreciated
  9. XJ550H
    this is a 82 xj 650 doide block same as a 550
    4U8-81980-M0-00
    resistor and diode are oil light
    then a diode for sidestand relay
    and a diode for headlight
    650G diode.PNG this is a 80 xj 650 diode block
    no sidestand set up
