Xj550 not charging
Discussion in 'XJ Technical Chat' started by Daniel McCarter, Sep 27, 2022.
  1. Daniel McCarter
    Daniel McCarter New Member
    Cambridge Md
    I'm having an issue with my 81 xj550. My mechanic says the bikes not charging but everything is testing fine. It's not charging the battery. Anything we should try or should replace? He's going to clean the brushes and check for any breaks in the wiring tomorrow.
  2. Jetfixer
    First thing common denominator is the battery old , or fully charged ? With bike running put a voltmeter on the positive terminal see what it reads at idle and rev it to around 2000 rpm and check should be 13 volts or so .
  3. Daniel McCarter
    Cambridge Md
    Battery is only about a year old and charged.
  4. Franz
    Do you have battery voltage getting to the alternator brushes?
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    The 550 has a built in voltmeter when running it should sit around 14V
    Daniel McCarter likes this.
