Xj750 oil level sensor
Discussion in 'XJ Technical Chat' started by Niall hicks, Oct 25, 2020.
  1. Niall hicks
    Niall hicks New Member
    Northern Ireland
    Hi guy I’ve a xj750 seca that had the speedometer with Atari I now have removed it and fitted new speedometer, I’m now looking to get a oil pressure sensor to replace the level sensor my xj has, can someone please tell me what model has the sensor I need? Thanks from sunny Northern Ireland
  2. Jetfixer
    As you have figured the oil light is only oil qty . To put an oil pressure gauge you have to drill and tap into an oil galley , I cannot say exactly where believe on the right side of engine . Personally I do not worry about the pressure more concerned with qty :D
  3. XJ550H
    there are 2 styles of oil level sensor one for the atari units which is on when full and the xjs with standard style clusters have a switch that is off when full.
    this is a long list of the style you need
    https://www.partzilla.com/product/y...?ref=21d473f819f4d37a6964719f717427b0add578a1
    as far as an oil pressure switch nothing that would go into the level switch hole.
    you could pull a plug on the side of the head and install one there
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    You got an oil cooler? If so it's easy. If not more hassle than it's worth? My Kawasaki gt750 had a plug in the gallery ready for it, under one of the side covers.
  5. Niall hicks
    Northern Ireland
    Thanks guys, I just want a oil light that goes out when started if the oil level is ok and on when not?
  6. XJ550H
