Photo of new fusebox install
Discussion in 'XJ Technical Chat' started by fjpish, Nov 16, 2008.
  1. fjpish
    fjpish New Member
    New Jersey
    I thought I would share this photo of my new fusebox install. This is the box from chacal (HCP378BC Replacement FUSEBOX). Old fuse box is removed, tool tray support is cut away to allow new fuse box to be mounted to airbox. There is still plenty of material left to support tray and the attached ingnitor. Spade tabs (barely visible) are angled towards front to allow existing wires (with new connectors) to reach. Only the four fuses to the left are used. The others are left in there as spares. No more glass fuses! Woohoo!
  2. artgostick
    artgostick New Member
    nice and clean install. well done.
  3. Zookie400
    Zookie400 Active Member
    Connecticut
    took the words right out of my mouth....looks factory, thumbs up!
  4. chacal
    Very nice!
  5. bill
    bill Active Member
    Raleigh, NC
    Great Job!
    Textbook. Thanks.
  7. shangovi
    shangovi Member
    Burtonsville MD
    Beautiful job! I will be doing the same soon might need a few pointers :D
  8. MN-Maxims
    Very Nice
  9. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Funny this post was brought up tonight as I was just about to post on how I spent this Sunday evening.
    I have owned the bike for 12+ years now and had always cringed when I looked at the fusebox mess the PO had left for me. The tangled mess never gave me any problems that I am aware of but I am happy I finally got around to cleaning it up a little.
    As you can see from the photos below the PO had spliced inline fuses into the harnes using "competition orange" wirenuts. Though they never gave me any trouble I was suprised at how much corrosion was under the wirenut on the main circuit.
    Shangovi when you begin plan NOT TO BE IN A HURRY, use a high quality pair of wire strippers/crimpers and most of all shrink tube is your best friend
  10. WiseManSage
    WiseManSage New Member
    Armidale, NSW, Australia
    Ive also done the same for my XJ. Help me with loads of problems i was having. Very nice install.
    Here are are few pic of my handy work....
  11. Polock
    :cry: i like my glass fuses :cry:
    i think they might be original
  12. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Polock. I double dog dare you to push on the clip ends that hold the fuses! If you do this, don't plan on going anywhere because they are very likely to break. The only time my bike has let me down is when a fuse clip broke 100 miles from home. I jammed the fuse into the bottom of the clip and made it home. I wired in 4 waterproof blade fuses and things have been fine ever since. It's not as pretty as those boxes that Chacal sells but I didn't know he had them at the time.
  13. MN-Maxims
    Polock your lucky that those cheap clips Yamaha used have not broken yet. I just touched mine and they broke. You must have gotten the only good ones they made.
  14. MN-Maxims
    SecaBob Nice work also. I just love the creative ideas you guys have here.
  15. yamaha4life
    yamaha4life Member
    OH---IO
    don't worry Polock i'm knocking on wood for you i need to upgrade also i have the same kind SecaRob had and are starting to get in the way
  16. Polock
    i know, i'll look at them before spring
    the sad part is i have a new fuse block on the bench, but i have a whole bunch of new glass fuses too
  17. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Thanks! Not sure how comfortable I am with the connectors sticking out like that. I'll probably fabricate something to cover them up
  18. wizard
    I used a food container lid.
  19. MN-Maxims
    Awesome Wizard
  20. yamaha4life
    yamaha4life Member
    OH---IO
    Mr.Wizard...lol i call you Mr. out of respect 8) not sure if that pic makes your bike that much cleaner or me that much more hungry wish that would work on my 750 but would restrict air flow
  21. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    fj, nice job, looks professional. I need to do mine as well.
    ranger & mn-max, i had the same thing happen to me in my process of resurecting my 650, i put new fuses in it last week & wouldn't you know it one of the clips broke. i just barely touched the darn thing & plink, it broke. i gotta upgrad!
  22. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Wizard that is a fantastic idea. I'll put my son's Lego's away now and head toward the kitchen.
    Great Job!
  23. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    very ingenious idea wiz, great work. i have watched you thread on your new project bike, you truely are a wizard
  24. WiseManSage
    This would have to be a first for my eyes but never the less. GENIUS!!
  25. RickCoMatic
    Nice stuff.
    When you do something like that; you deserve praise.
    That's a great looking Fuse Panel upgrade and Custom mount.
    Grab yourself any prize off the Top Shelf.
    You won it!
  26. fjpish
    fjpish New Member
    New Jersey
    Wow, Wizard. That's truly oustanding!
    And SecaRob, I like the shrink tubing. Smart move.
  27. Pacocase
    Pacocase Member
    MD
    I used to have pics of the job I did on my Seca on here. Ran out of room and deleted them from my main pics tho. Here's what it looks like. Some kind of animal made a nest and chewed almost all the wires away.There was a lot of new wire and solder involved there. Of course, later I took out the airbox and mounted it on a food container similar to what Wizard did. The airtight container is excellent for holding tools/maps/registration etc. And I still kept the original tool tray.
  28. RickCoMatic
    Pacocase:
    That's nice work; too.
    BUT ...
    There's a problem with using RED Wire to redo wiring.
    Anybody doing Troubleshooting would expect RED Wires to be: +12V (Hot)
    Even though you have the Cover Labeled ... the ALL RED Wires are a CurveBall that will fool somebody tracing an Electrical Fault.
    Not that I expect you to submit the bike to be judged and graded.
    But ... IF you DID enter the Bike in a Contest where they were looking closely at the details ...
    You'd lose some point for not recycling an old Wire Harness and using Matching Color-coded Wires for the Upgraded Fuse Panel.
  29. shangovi
    shangovi Member
    Burtonsville MD
    SecaRob: i will need all the advice I can get come upgrade time as I'm not all that great a mech! hope I can get it close to what you have done. Great work nice n neat n clean.
