Fuel/Air mixture screw location?
Discussion in 'XJ Technical Chat' started by SnoSheriff, Jul 27, 2006.
  1. SnoSheriff
    MB, CAN
    I haven’t had the need to work on my carbs yet. I’m thinking on getting color tune plug to check/adjust my fuel mixture as I can tell my cylinder #1 is running colder then the rest. I did this by placing my hand on the exhaust pipe as the bike was warming up. Before I tackle the job I’m wondering if someone could describe (picture would help) where the carb mixture screw is located :oops:? I’m guessing each carb has it’s own mixture screw?
  2. hessenr00ts
    hessenr00ts Member
    Minneapolis, MN
    As requested! :D
    Left and right side, just for details sake.
  3. SnoSheriff
    MB, CAN
    NICE, thank you :mrgreen:. Is that a Phillips screw? How do you guys get in there on the 2nd and 3rd cylinder? Looks like it may be a bit tight.
  4. hessenr00ts
    hessenr00ts Member
    Minneapolis, MN
    It's a thin flat head screw, nothing crazy.
    I've not done it myself but for the middle screws I'd use one of those 90degree angle attachments on a long socket handle.
  5. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    They make a special tool for it, but I find it just as easy to remove the tank bolt and take a short 2X4 and prop up the rear of the tank and use a small pocket screwdriver.
  6. jdrich48
    jdrich48 Member
    Also if they have never been adjusted they may have the brass plugs still in place.
  7. SnoSheriff
    MB, CAN
    If they do have the brass plugs, do they just pop out somehow?
  8. jdrich48
    jdrich48 Member
    You will have to carefully drill a small 1/8" hole in the center, then take a sheet metal screw that fits snug in the hole and wiggle and pull with a pair of pliers. The plug is about 1/8" thick drill carefully.
  9. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    I've included a schematic of a carb but it looks like everyone else pretty well showed you.
    I drilled the plug with a 3/16" drill bit but be careful as everyone else said because you can go thru pretty fast and damage the screw head.
    The screw head is small flat blade and I've found for the #2 & #3 carbs that a double ended bit for a reversable screwdriver fits in there nicely
    one side has a straight blade and the other is a phillips.
    The color tune is a good idea and if you dont get the pretty bunsen burner blue in the window but only see spark then that cylinder is rich or has no gas. if the plug comes out wet then it's rich and if it comes out dry and clean it's lean.
    Mike
