Decent YouTube Fork Seal Replacement Video
Discussion in 'XJ Technical Chat' started by Artie(RT), Mar 9, 2009.
  1. Artie(RT)
    Artie(RT) Member
    Raleigh, North Carolina, USA
    In addition to all the information on this forum, I found the YouTube video below (the link takes you to part 1 of 3) to be very helpful. The forks they are working with are much more complex than the XJ bikes I know about (which I readily admit my breadth of knowledge is limited). Nonetheless the overall process is very similar and helped me quite a bit. Hope it helps you if it's the first time you are attempting this repair.
    Note in place of the fork seal driver tool (about $90.00) I took the advice offered on this forum and used a long 1.5 inch diameter piece of PVC pipe taping it with a rubber mallet to seat the oil seal. Just make sure the end you drive with is the super straight factory cut end.
    http://www.youtube.com/watch?v=W2G-b66F3es
