Chain Guide Question
Discussion in 'XJ Technical Chat' started by tcoop, Sep 12, 2009.
  1. tcoop
    tcoop Active Member
    South Weber, Utah
    I was not able to shift out of first gear, so I pulled the engine and Cracked open the case. I found the 1/2" by 1" pice of hard plsastic that was keeping me from shifting.It does not look to be from the cam chain guides.
    The chain guide fo the for the altenator is in two pieces. My question here is should it be? Or do I need to get a new guide?
  2. RickCoMatic
    You are looking at Primary Chain Guide.
    You should remove the remnant and install a whole new guide.
  3. tcoop
    tcoop Active Member
    South Weber, Utah
    Thanks Rick. Looks like I will be ordering some new parts.
  4. tcoop
    tcoop Active Member
    South Weber, Utah
    How much give/slack should be in the starer clutch chain?
