Hasersys, The Rust Build. Bobber
Discussion in 'XJ Modifications' started by Hasersys, Jun 22, 2010.
  1. Hasersys
    Hasersys Member
    Sebastian and Tampa Florida / Chicago Il
    I have been working on this for about two months. When I have time after work. The bike is lowered 2" in the back. I will need to rebuild the caliper and master cyilinder. The piston in the caliper is pitted pretty bad. I assume I should replace it, but could it be reused? Also if i purchase the rebuild kit, The entire rebuild kit with piston, what do I need to reuse from the caliper? How difficult is it to rebuild the mc, and caliper. I have taken it apart so long ago I am wondering how I am going to get it back together, even with my pictures.
    How dose this fender look?
    what is the best way to remove rease from the neck? I am going to replace neck bearing with the tapered. I am also sure I have a million questions that I can't think of.
    Hope my build is liked.
  2. 16ozbud
    16ozbud Member
    louisiana
    The fender looks good, but.......
    My personal opinion is that you need to redo the hardtail. Seems like the tubing you added needs to come from the wheel to the tank. That's a pretty rough transition to try to mount a seat onto. But I don't know what else you have planned. I don't have your vision of what your bike will be, so don't mind me.
  3. Hasersys
    Hasersys Member
    Nah, It will be nice when it is done. Mounting a seat wont be hard at all. I am trying to figure out if I want to mount the fender by bolting it on or just weld it on.. I really should mount it so it bolts on but I do not feel like fabbing some parts up.. Might just wait untill I feel like it heh. The seat is going to mount from the back of the tank to past my cross member. My springs are going to mount near the middle point of my crossmember and the tubes coming up in front of the fender. It should all flow very nice. The ride height will make it all like up in a even line.. well some thing like a line.. Kinda what I see..
  4. 16ozbud
    16ozbud Member
    louisiana
    Cool, man. Your opinion is the only one that matters anyway. Keep us updated.
  5. koolaid5
    koolaid5 Member
    Chambersburg, PA
    more work :D I want to see how you get the seat on there.
  6. Cmccully04
    Cmccully04 Member
    State College, PA
    looks good so far man, Nice work.
  7. RickCoMatic
    At this stage of your build, make sure the frame and all the welding is all cool.
    If this is your first shot at a custom bike; get somebody to look-over your work without the attachment you have to the project.
    Rebuilding a Master Cylinder is easier than putting-together a Computer Desk from IKEA
    http://www.ikea.com/us/en/catalog/products/30064057
    WAY easier!
    The Caliper is Aluminum.
    Getting a Caliper Piston and totally cleaning and rebuilding a
    Yamaha Brake Caliper, ... is ALSO easier than assembling a Computer Desk from IKEA.
    Splitting the Cases and replacing bent Shift Forks, ...
    Not easier than assembling a Computer Desk from IKEA.
    Close though.
  8. Hasersys
    Hasersys Member
    I just readup on it last night, and i think I got it thanks.. lol.. ikea
  9. Swissjon
    Swissjon Member
    I'm with you Hasersys.. I like the shorter wheelbase your frame is gonna give the bike. I see a lo of hard tails on here with a big rake on the front forks and you end up with yur classic chopper.. Chuck some monkey bars on top for good measure.. Maybe that's the point of a hardtail, I dunno, but I come from a sports bike back ground.. My bike's got a cafe racer inside her, and with the bike set up like you have, it's gonna end up going down that line.. Put the right paint job on her and you'll have a really sweet ride.
    Have you tried carb cleaner on your grease.. That stuff eats through most things.
  10. Hasersys
    Hasersys Member
    I had bobbed my rd250. Granted I love keeping bikes in original shape the bikes I change the frame to were little to nothing to purchase and had issues. This bike was bought over a year ago. The Po chopped the back off and rigged a back fender. I left the bike as it was and rode it for a year. I bought it for $300 and got my money out of it. I have rebuilt the carbs, and that is about it.
    The way the frame is I can still use the original airbox.... I am not sure if I am going to go that way yet though. Although I did think it was an idea.
  11. Hasersys
    Hasersys Member
    Using rebar, I fit it snug against my tire. I used it to also raise my fender up giving it a little pop. I then bent rebar around the back of the fender and welded it on.
    Oh, in regards to my welds... They look like crap but they are strong. I can't keep a consistent bead on this welder. It is a bit sporadic, I get a good bead going then I loose arc. I get good penetration. This is cause by the wheels that feed the wire, they slip because of wear. I put a c clamp on it and it helps a little.
    Now I may round off the fender. I am going to have to stare at it a bit to figure that out.
  12. Swissjon
    Swissjon Member
    Take it to a diamond point, not round.. It'll be different and look really cool..
  13. Hasersys
    Hasersys Member
    So my girlfriend posted a picture of me from when I was in highschool. I had built this mini bike and me and a friend were messing around.. Once you see the picture you will see what I am talking about. She posted it to Tmz, they are having a contest. Currently we are in the finals. We are number 18. On monday they open for finals, so PlZZzz go vote for it on monday. we win a little cash, but we also win biker gear. One thing I could use is gear.
    I woke up this morning to my gf yelling and laughing. She was yelling at me to wake up and look. She handed me her phone and here is this photo.... some what embarrassing... I had no idea she posted this... That was the first bike I had built, I miss it. I am on build 3 now.
    Any ways check it out, and help me out and vote on monday for it.. Or at least check it out. It is funny as hell.
    http://photos.tmz.com/galleries/tmzs_bi ... t&id=72876
  14. Hasersys
    Hasersys Member
    Worked on battery box, and seat. Might move seat forward about 3". Both are just mached up a bit.
  15. Hasersys
    Hasersys Member
    SEAt, measuring drunk only leads to failure.....
  16. iwingameover
    iwingameover Active Member
    Just my $0.02 ....
    You may want to gussett those rear bars. The angle is pretty wide and there will be a lot of force pushing up on those bars.
    My point being they're alreay straigheter than not and the force will want to make them completely straight.
    But I'm not an expert....
  17. Hasersys
    Hasersys Member
    Your .02 makes close to a nickle in my book. I was considering it already. I thought about 4 gussets. Two near the bottom of the seats, and two.. one on each side.. On the last bit towards the last up tubes. Rounding them off a bit to make them look fancy and what not. I want to get the frame welded up and check it out a bit more before I do. This welder is on its last leg, although they look bad they are strong. I am going to look more into it later.... This stuff is also not the easiest to weld on.. Most of what I get for free is scrapped out metal from work. Free = I am using it. The tubes are chromoly. A bit tough to weld, but it can be strong. The negative is that it will transfer A LOT of the force into the rider, and rest of the frame. This stuff doesn't budge. It is best preheated and tig welded, but It really welds just fine.
    Bottom line is that I am going to probably throw gussets onto it and then watch for any bad signs. These tubes were meant to hold turbines.... they DO not bend so the bike will be hard on my butt, and hard on the welds.
  18. iwingameover
    Probably even more important to do the gussetts with those back legs being chromemoly. The original frame seems to be fairly thin and I'd believe plain steel your rear legs are now much stronger than the frame their welded to.
  19. Swissjon
    Swissjon Member
    BEER + POWER TOOLS = BAD IDEA.
    My dad chopped his little finger off that way! Lucky for him it wasn't his whole hand!
    Use your grinder and welder ONLY when you're sober.. Stick to mechanical stuff like wrenches and screwdrivers when you've had a skinful, you're less likely to do permenant damage to yourself OR your bike (Far more important! LoL!)
  20. Hasersys
    Hasersys Member
    Heh, was still sober. I am sure there are some others here who feel the same, but when I have had a couple drinks before I weld they come out better. It causes me to relax more.
    Iwingameover, I agree. I was thinking the same. I get a lot of metal free, I take what I can get and I make it work, and work safe. lol What I get is scrap from work. It is all in good condition with no issues. Most of it was scrapped because the parts do not meet the correct measurments, and ended up in our maintenance dept. They use them to build tables or what ever they want really heh. I go to them and ask if they have any scrap I can have.My bike is now part plane.
  21. Hasersys
    Hasersys Member
    OH and swiss jon Also.
    Beer+fireworks= Bad idea.
    My dad ended up with 12 stiches in between his middle and pointer finger. He thought it was a good idea to run around the block... drunk.... shooting a morter. The bottom of some morters are sharp...
    Ppsh Rednecks. :roll:
    Darn, I am born into it. :lol:
  22. Hasersys
    Hasersys Member
    I have just about gotten the frame done. I have been in the middle of a move.
    I have been looking around, still not sure, but I would like to install tapered bearing. What do I need to do to the neck to install them? Dose the reace in the neck need to be removed? I looked at it but it looks like they do not come out.
  23. hogfiddles
    Yes, the neck tube should be empty. If you look/feel carefully, you'll find the very thin edge of a lip that you can get a punch onto and start slowly driving the races out. It CAN be done, it just takes time, and don't get aggrevated. Get the races out, clean the old grease out, install new tapered sets, grease and assemble. Many of us have done it....you can, too.
    Dave Fox
  24. Stokie
    Stokie New Member
    Stoke-on-Trent, England
    When you re-install the new races, put them into the freezer (overnight). Warm the neck tube a little if you can too. They're an interference fit, so making the race contract should make it easier for you to fit :)
  25. Hasersys
    Hasersys Member
    I was starting to belive they didn't come out. I haven't worked on them in a bit but as much as I have, they haven't moved. I will get back at them this week.
  26. Hasersys
    Hasersys Member
    I still need to clean up the swing arms paint, and on the forks. The frames good to go.
  27. Hasersys
    Hasersys Member
    I just finished the seat.
  28. Hasersys
    Hasersys Member
    Ops, I forgot to resize this one. Sry.
  29. grinder
    grinder Member
    norfolk,uk
    looking very gd dude.im looking forward to seeing how this turns out.
  30. Hasersys
    Hasersys Member
    Ahh thanks, Working on the tank right now. I found the time to do it now.. just lost the money.. This is now a Laid off build.. I no longer build airplanes I build my motorcycle.
  31. Hasersys
    Hasersys Member
    This is it mocked up with the tank, still needing a bit of work. Wanted to get an idea on the bars. Was wanting to run drag bars, but I have clubman around so put them on to see it and I think they are good upside down.
  32. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Mine is an outta work build too. The bike will help keep your sanity. Lookin good so far. Can't wait to see it done.
  33. quikcobra
    quikcobra Member
    Orlando Fl.
    I like it, I guess these bike make the best looking bobber. I go threw the site and theres alot of nice bikes.
  34. Hasersys
    Hasersys Member
    Sweet, Orlando. Go there a lot. These aren't bad bikes to bob, but I wouldn't mind having one to restore. This one had been cut up by the Po. I got it from someone in Okechobee for $300, rode it for a year in Tampa, brought it back to Sebastian to rebuild it. It is nice being able to find them on Craigslist for a good price. The Orlando area is always having xjs. I have found a good amount of parts bikes in the area.
  35. koolaid5
    koolaid5 Member
    Chambersburg, PA
    nice start....
    Start selling f'n plasma or something to fund the build :D
  36. Hasersys
    Hasersys Member
    .. I think I will just sell my girlfriend......
  37. koolaid5
    koolaid5 Member
    Chambersburg, PA
    that works too. Hope you can get a decent amount for her. Send me pics... I might be interested in renting her for a few.
  38. Hasersys
    Hasersys Member
    I need some help on for my headlight, I am going to start looking for one. I do not need anything to nice and def need some thing cheap. It would be nice to have some thing that I will not have to fabricate anything to mount it. I can if I have to but rather not. I also would like some thing small.
    If anyone has suggestion on a good light, or place to purchase one let me know.
    I have also seen the fork mounts that they sell on ebay, but not sure what sets of lights would fit on them.
  39. koolaid5
    koolaid5 Member
    Chambersburg, PA
    I have a small single round headlight that I'm not going to be using.
  40. Hasersys
    Hasersys Member
    Can it be mounted easy. I am just not wanting to have to make any thing els. I am down to the point where I would love to stay away from fabbing more.
  41. koolaid5
    koolaid5 Member
    Chambersburg, PA
    it has a single small bolt coming out of the bottom to mount it. send me a pic of the front of your bike, so I can see how you could mount it.
  42. Hasersys
    Hasersys Member
    I know the kind, I had one on my rd250. I would have to make a mount. Right now I think it may be the easy way out. I have seen the othere lights with the mounts that mount to the sides of it and am wondering is a mount like the one in this ebay link would fit on our forks.
    http://cgi.ebay.com/ebaymotors/TRIUMPH- ... ccessories
    If I have to I might go with the type of light you are talking about. I am trying to see what my options are.
  43. Hasersys
    Hasersys Member
    Oh, and the front is stock so far, nothing to mount to.
  44. koolaid5
    koolaid5 Member
    Chambersburg, PA
    I was able to mount it to my stock front end. There is a little spot for it to mount to dead center. I forget what was there before though.
    Let me know if you need anymore info or pics and if you're interested.
  45. Hasersys
    Hasersys Member
    I am interested in pics of where. I would love to get an idea of what I am going to be doing.
  46. koolaid5
    koolaid5 Member
    Chambersburg, PA
    can you send me or post up a close up pic of your front end under where the stock headlight goes?
  47. Hasersys
    Hasersys Member
    Yea I will. I am wanting to mount it to the bottum trple tree, but I was just looking at it and I have no hole to mount through it. I only have two bolt holes where I can fab a peace to mount an l bracket onto it. it would mount where the brake line gose... like where the unioin is the l thing.. Do not know the name. Idk, I think I just need to brake the bank and get a light.. then fab what i need lol.
  48. koolaid5
    koolaid5 Member
    Chambersburg, PA
    I have a bolt hole on the lower triple. I have a 750 SECA though... guess it's different. A piece to tie into those two holes you have won't be hard at all though.
  49. Hasersys
    Hasersys Member
    Got my rear wheel done also, just waiting on parts now.
    This is going to be a very bear bobber. I am trying to cut down as much as possible. No speedo, no tach, Hopfully I am going to get a moble gps with a mount. That way I will have a way to keep track of my mph.
  50. Orange-n-Black
    look's good so far.
