tachometer for speed readings-(now includes gps readings)
Discussion in 'XJ Technical Chat' started by snowwy66, Jun 26, 2010.
  1. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    if anyone knows the rpms for the speed could you please post.
    my speedo don't swing in full speed.
    i know 55 is about 4700. as i had this bike once before. i have no idea what's after that. and speed around here is 75.
    i go with the car flow. but when your out in the boonies. car flow isn't available.
    i'd like a listing in 5k increments up to 7k if any one can gimme that please.
    i was going to mount my blackberry for a gps speedo. but apparently none of the programs will work without internet signal. wished i still had my old windows mobile phone. they all worked on a deactivated phone.
  2. Jotr
    Jotr Member
    Ottawa, ON, Canada
    Re: tachometer for speed readings
    on mine, every 10km + is another 500rpm's or there abouts....160km was 7500rpm!
  3. snowwy66
    snowwy66 Member
    i need mph though. LOL.
  4. Jotr
    Jotr Member
    Ottawa, ON, Canada
    160km / 1.6 = 100mph :D
  5. cutlass79500
    lawrenceville georgia
    i think what he means is rpms at 60 65 70 75mph
  6. Jotr
    Jotr Member
    Ottawa, ON, Canada
    oh...right. Its early...well....early enough. *Sip of Coffee*..... :)
    If I get out today for a ride, will bring my portable GPS and switch it to MPH and take some readings. Headind to the lake first to do some work prior to the Canada Day weekend
  7. snowwy66
    snowwy66 Member
    around here the speed limit is 75 outside of the population. i had this model brand new when i was a senior in high school back in 84. so i know around 4700 rpm is 55 mph. but after that i have no idea. and 7k is my max rpm on the freeway.
    i can't use my deactivated blackberry. if i can find a cheap arse old tomtom or something i'd be tempted to mount that. i bought a 12v cigarette plug to wire up. i just need something to plug in.
  8. Polock
    jensonUSA
    or the ratios are in your shop manual, measure your tire and get out a calculator
  9. cutlass79500
    thats a great idea i think i will get 1 just to have it. great price also thanks for the tip
  10. snowwy66
    snowwy66 Member
    i bought one of those. but mounting something made for a bicycle onto a motorcycle is a whole different story.
    it's not exactly an easy task to mount that sensor on the front tire. there has to be 1mm spacing.
  11. Polock
    it's not easy but it's not hard
  12. snowwy66
    snowwy66 Member
    mines a little different setup. i seen your pic once before and test mounted. i've got a 5mm gap. the sensor is a little thinner. and the magnet is a little o-shaped peace that don't protrude as far.
    i wished they made a cheap gps speedo. youi can get software for free on phone. but an actual unit is boo goo bucks. pfft.
  13. snowwy66
    snowwy66 Member
    oh hell yeah, just the ticket i've been looking for. $18 for this mount. i have a friend that paid $100 from the local motorcycle shop. this'll be perfect for mounting and using my cell phone as a gps speedo. just gotta wire up the power supply now.
    http://store.cheapdroids.com/Amzer-Univ ... Mount.html
  14. snowwy66
    snowwy66 Member
    yesterday was the ride and using my brand new EVO cell phone mounted to my brand new cell phone mount. i had a 12v cigarette plug hooked to the battery. and a 12v phone charger run under the tank plugg into the cigarette plug. here's the results
    55 mph = 4500 r's
    60 mph = 4900 r's
    65 mph = 5300 r's
    70 mph = 5700 r's
    75 mph = 6100 r's
    80 mph = 6400 r's
    85 mph = 6800 r's
    88 mph = 7000 r's that was all the breath she had.
    these numbers are GPS SPEED. your mechanical gauge will read about 7 - 10% percent higher. mine reads 30% slow.
  15. KenBoP2
    KenBoP2 Member
    Madison,Tn
    Re: tachometer for speed readings-(now includes gps readings
    Snowwy Thank you very much for that info, very helpful and needed too.
