Lube for gas cap latching mechanism?
Discussion in 'XJ Technical Chat' started by luvmy40, Jul 30, 2010.
  1. luvmy40
    luvmy40 Member
    Y-Town, OH
    I did a search for "gas cap" and "gas cap lock" and came up with tons of threads/posts about stuck lock cylinders and removing stuck caps but no one had any input on what a good lubricant might be for the actual latching mechanism.
    I have used ordinary bearing/axle grease, White lithium grease, Eezox( a gun lube/metal treatment) and dry Teflon lubricants of various mfgs.
    All worked well for a while and all failed after a few weeks or months. I get a lot of oxidation on the aluminum latch mech. and it starts to seize up. A little cleaning and lube and it's good to go... for a while.
    Any ideas of what might last a bit longer at least.
  3. Polock
    GunKote
  4. luvmy40
    luvmy40 Member
    Y-Town, OH
    Thanks!
    I have a tube of the clear synthetic grease on the way.
    BTW, with shipping it was cheaper by a few dollars from Tri-Flow rather than Crawford.
  5. RickCoMatic
    I lube all my locks and Ignition by dipping the Key into some Marvel Mystery Oil and working the locks.
    It's one of those "Once-a-monther's"
    It doesn't accumulate and can be cleaned-out with a douche of alcohol.
  6. mlew
    I like using a dry film lube like silicone or graphite. It does not attract dirt like wet lubes. Thats just my preference.
  7. bigfitz52
    The gas cap is a special case. The whole cap is part of the "vent" and lives in a constant atmosphere of petrol fumes, which tends to clobber lubricants and promote corrosion on the moving parts of the latch.
    One thing that will help: when cleaning up the latching "internals" polish the stupid "pot metal" as shiny smooth as you can, wherever possible. It helps it stave off corroding.
    Re: That white lithium grease: except for the throttle barrel, that stuff has very few practical applications on a motorcycle. It's just too "wimpy."
  8. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    indeed. the only thing I ever use white lithium grease for is certain rough and tough polyurethane O-rings for various pneumatics applications that degrade if subjected to petroleum lubes. I'm sure it has other uses but I haven't run across them.
    For locks and gas caps and such I've had good results with plain ol' household 3-in-1 oil but I don't subject them to much dirt. If I do have a problem with such, wd-40 would rinse it fine.
  9. junkmn
    junkmn Member
    Colorado
    Kroil
  10. lanthren
    lanthren Member
    Caldwell Idaho
    +1 on the graphite, locksmiths like me will tell you the same thing
  11. Militant_Buddhist
    Redmond, WA
    assuming it hasn't been and won't be subject to moisture.
