Can I put 82 Seca Carbs on my 82 Maxim 750?
Discussion in 'XJ Technical Chat' started by Metal_Bob, Sep 1, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    This has probably been asked before and I'm to tired to search at the moment just before bed.
    Can carbs pulled off any 82 XJ750 Seca be used for my 82 X750 Maxim?
    If the rocker/connecting bar/whatever it is called is different are the "bodies" which everyone cleans and rebuilds the same?
    I'd rather find a cheap set of carbs to work on than risk turning my 1st ride into a paperweight...
  2. chacal
    Yes, they can!
  3. Metal_Bob
    Bourbonnais, IL
    Woot!
    Thanks.
    Are they 100% swapable? Or have to reuse parts?
  4. stereomind
    stereomind Active Member
    Tulsa, OK
    100% swappable, assuming the donor carbs have not been re-jetted for some reason.
  5. TIMEtoRIDE
    You have to re-use the center 2 chrome hats, or it just won't run right. :lol:
  6. schooter
    it will run better if you take the seca's muffler bearings and put them in your maxims exhaust when you swap carbs, as they're a sportier bearing
  7. Metal_Bob
    Bourbonnais, IL
    Good to know and simple enough sounding
    Unless I get a donor seca that's not likely to happen...
    Basically, I'm cheap/broke and would rather work on a 2nd pair of carbs rather than risk totally F'ing up my working carbs on my first bike.
    My carbs already need the tiny #2 adjuster screw extracted or retapped.
    In a former job, I was never very good at extracting screws. It doesn't help those screws are tiny and brass... So who knows what else will probably go wrong.
    If it's a project for ME, something always goes wrong. I could do the same "project" for 4 other people, and mine will be the one that gets f***ed up or has problems. So typical for me /sigh
  8. MN-Maxims
    Swap em out and see how it runs.
  9. stereomind
    Tulsa, OK
    You guys are funny :mrgreen:
    Everybody knows you only replace muffler bearings if the johnson rod is bent. And you may as well forget about doing it yourself unless you have a left-handed screw driver.
  10. Metal_Bob
    Bourbonnais, IL
    More like mean... LOL
    Though we use to get new people in the shop telling them to go find the:
    Left Handed Cresent Wrench (no no go ask so-and-so he had it last)
    Aluminum Magnet (its brand new invention we bought recently)
    Mesh Suction Cup (We use to make these mess parts that were a bitch to pick up with normal tools/hand).
  11. schooter
    my favorite is the metric cresent wrench
  12. Metal_Bob
    Bourbonnais, IL
    So silliness and fun aside...
    Anything in particular I should look for or RED ALERTS in flea bay or similar listings?
  13. Metal_Bob
    Bourbonnais, IL
    For reference will any other model / years bolt on with just some minimal parts change over? I. E. Just rejetting and few other cheap parts. Would 81-82 xj 650 carbs do the job, or other 750 maxim or seca years?
  14. bigfitz52
    Pretty much. There might be differences in throttle bracketry and the like but all of the 650 and 750 XJs used the same series Hitachi carbs.
    All of the 550s used the same Mikuni carbs.
    The only thing to beware of is eBay sellers listing stuff as being for XJ550/650/750; that's rarely true.
  15. Metal_Bob
    Bourbonnais, IL
    Thanks a bunch!
  16. MoralDK
    MoralDK Member
    Spokane
    This swap will go nowhere without a hammershackle!
  17. Orange-n-Black
    Don't forget to clean them with a bucket of steam. :wink:
