Mod my Triple trees !!!
Discussion in 'XJ Modifications' started by BillB, Mar 5, 2011.
  1. BillB
    BillB Active Member
    Tulsa Oklahoma
  2. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    To be honest, the best source of information would be the company that builds them. Send them an email and see what they say. Unless someone on here has bought a set for an 82 XJ 650 recently.
  3. mlew
    They probably cost more than your bike did.
  4. Hillsy
    Hillsy Member
    Well, for starters they're for 43mm forks, your XJ has 36mm.
    The stem length / diameter is probably different - which means new bearings / spacers.
    The width between the forks will no doubt be wider than your XJ - which means a new axle, spacers, disc mount, mudguard mounts, etc.
    Other than that they should bolt straight up :lol:
