An 'Oh Hell' moment
Discussion in 'XJ Technical Chat' started by Rickinduncan, Apr 2, 2011.
  1. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    So I decided to check my valves today on my 'new to me' 750 Seca. The good news was that everything was in spec. The bad news, as I was torquing down the valve cover bolts with a digital torque wrench set to 7.2 lbs, one of the bolts wouldn't begin to tighten. I'm guessing the previous owner had overtightened it at one time and stripped it out. Am I going to have a big problem with this? Would a heli coil fix it? I guess I would be feeling worse if I had done it! - Rick
  2. Ravenz07
    Ravenz07 Member
    Pull the cover off, check the threads. Might be able to just tap it.
  3. RickCoMatic
    Depending upon which Bolt is stripped, ... you have several options.
    If the Threads are on a Cam Shaft "Bridge" (Not a Bearing cap), ... all you have to do is replace the Bridge.
    If its on a Bearing Cap:
    Insert a HeliCoil Thread Restorer.
    http://www.emhart.com/brands/heli-coil
    The Threads need to be Drilled and Tapped slightly oversize.
    A HeliCoil Insert placed into the newly tapped hole and permanently set.
    JB Weld (Not recommended)
    Spray the Fastener with Silicone Spray
    WRAP the Fastener with 2 or 3 Layers of Teflon Tape.
    Coat the Teflon with JB Weld.
    Place the Fastener in the Stripped Hole cleaned and prepared for the repair.
    Finger tighten.
    Remove excess.
    Let Cure. Remove fastener.
    (Keep TEFLON Tape between Fastener and JB Weld.)
  4. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    It's one of the outside top end allen bolts on the valve cover, nothing internal.
  5. bigfitz52
    Heli-Coil it. My '81 came to me with all 4 of the outers on one side Heli-Coiled. It'll be fine.
  6. Robert
    Heli-coil, Thread-sert, Time-sert, Keenserts, all will fix the problem for little to more than a little money. I've had to fix a few on my "new-to-me" bikes due to over-zelous P.O.s. M6x1.0 and you're in business.
  7. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    OK thanks guys. that doesn't sound too difficult or expensive. Not something I'm used to since I also own a goldwing! - Rick
