XJ Lawn Mower!!!!!!
Discussion in 'XJ Modifications' started by Switz1, Feb 4, 2007.
  1. Switz1
    Switz1 Member
    Central Illinois
  2. danno
    danno Member
    Union Springs,New York
    Definitely "grass" involved,but I don't think they've been mowing it !
    Looks like fun!!!
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I could mow the lawn in about 12 minutes at 75 Mph! Thats awesome, but such a waste of an XJ!
  4. XJJeff
    XJJeff Member
    <a href="http://maps.google.com/maps?q=88.583765+4
    Now thats what this old guy calls cool.
  5. Stinky
    Stinky Member
    Flagstaff, Arizona
    I could get in to that.
  6. thefox
    thefox Member
    Central NY (@ college in W. PA)
    That is sweet!
    I actually bought my XJ to do the same thing with it. A buddy and I were going to put a motorcycle engine in a mower thinking it would be a fun project; we got a mower from his grandma and then bought the Seca from a guy my buddy knew for $100. After striping the Seca down I decided that the bike was in too nice of shape and we didn’t want to mess with the shaft drive so we abandoned the project. I reassembled the bike and have enjoyed it for the last 4 years/16,000 miles.
  7. xjlawnmower
    xjlawnmower New Member
    Forks,Wa
    Hi I am the guy with the xj lawn mower . I got the bike (82 xj750 ) for 150.00$ but the only thing on the bike that was good was the motor, so i put it in the lawn mower . it was fun to buld Thanks
  8. eatatjoz
    eatatjoz Member
    Mayflower, Ar
    sweet machine!
    I'm curious about the driveshaft to rear axle conversion. Do you have any pictures of the build?
  9. Fongdingo
    Fongdingo Member
    Charlottesville VA
    That looks like a fun build, Please post some pics of the conversion.
  10. xjlawnmower
    Forks,Wa
  11. eatatjoz
    eatatjoz Member
    Mayflower, Ar
    Nice, clean work. *two thumbs up*
  12. SnoSheriff
    MB, CAN
    That's an awesome project. I would like to make a dune buggy for my boys. So, here are some questions:
    1. What kind of welder do you use to weld that square tubing frame? Mig or arc? How many AMPS?
    2. What do you use for your rear axle? Is that just a steel rod?
    3. Do you just use the XJ brakes on that rear axle?
    4. It looks like you just cut the square tubing connections and welded. No bending needed?
    5. What is that steering mechanism on the front wheels?
  13. xjlawnmower
    Forks,Wa
    I used 1”x2”x1/8” square tubing , I welded it with a mig I’ve got a 140 amp that works good on the 1/8” tubing. The axle is ACRALLOY it is a lot like MOLY-KROME I got it at this site http://www.pmtsco.com/COLD.HTM I took the spline off the wheel (the one that fits into the drive unit) and machined a part to fit inside and bolt to it and used a ¼” key way on the 1” axle ( I had to hone out the drive unit a little for the 1” axle) . The brakes are off the front of the seca and a rear master cyl off a xs 550 and a disc off a go kart (ebay) . The front end is jr dragster spindles
