Stamped wheel codes
Discussion in 'Hangout Lounge' started by Dannymax, Sep 25, 2011.
  1. Dannymax
    Dannymax Member
    East central NY
    I have 2 wheels that I believe came off an XJ. They have 5 curved 'spokes', front has a single sided 11 3/4" rotor, .271" thick.
    The rims are stamped as follows
    Front: J 19XMT1.85X DOT
    MT 1.85X19
    F-07
    Rear: J 16XMT3.00 DOT
    MT 3.00X16
    R-10
    Spline & cush drive are attached to the rear.
    Is there a way to determine what bike/bikes they will fit from this info?
    The "swirly" spokes swirl toward the rear, so which side is the rotor on?
    If they've got splines in the rear, then it would have been a shaft-driven bike. So I'm guessing either 650 or 750 Maxim, but I thought the 750 had dual discs.
    Actually "stamped" or do you mean raised cast-on lettering?
  3. Dannymax
    Dannymax Member
    East central NY
    The rotor is on the left side, sitting on the bike.
    Yeah, definitely shaftdrive, 29 'tooth' spline.
    Oops....stamped isn't the correct term....raised or embossed.
  4. MiGhost
    MiGhost Well-Known Member
    Single disc on left side would make those 650 maxim wheels, but the drive hub would be bolted to the rear wheel. The cush drive was used only on the 550 models.
    Perhaps a pic might help in the identification.
    Ghost
  5. Dannymax
    Dannymax Member
    East central NY
    The drive hub IS bolted to the wheel, I assumed all shaft drives were cush mounted.
    I've tried posting pics but haven't gotten it right yet, I'll work on that.
    Thanks guys for the info.
  6. Dannymax
    Dannymax Member
    East central NY
    OK, let's see if this will work....
    Well I'll be damned!! Here they are.
  7. MiGhost
    Those are deffiantely 650 maxim wheels.
    Now to answer the other half of your question.
    Front wheel:
    4H7-25168-29-98 Yamaha CAST WHEEL, FRONT (1.85-19) | LOW GLOSS BLK
    Used on the folowing bikes
    XS400J/K - 1982 - 1983
    Maxim XJ550H - 1981
    Maxim XJ650G/H/J/K - 1980 - 1983
    Maxim XJ750J/K - 1982 - 1983
    Seca XJ750RH/RJ/RK - 1981 - 1983
    VIRAGO 750 - XV750H/J/K - 1981 - 1983
    VIRAGO XV920J/K - 1982 - 1983
    VIRAGO XV920RH - 1981
    The plastic cover on the right side of the front hub is removable to attach a disc for the dual disc setup.
    Rear Wheel:
    4H7-25338-29-98 Yamaha CAST WHEEL, REAR (3.00-16) (4H7-25338-20-98) | LOW GLOSS BLK
    These rear wheels use a different (smaller?) brake plate than the 750 Maxim/Seca wheels
  8. Dannymax
    Dannymax Member
    East central NY
    Thanks Ghost!! I sure can't ask for any better response than that! Think I'll check them for run-out, clean them up and see if anybody needs them.
    That's interesting about the plastic cover on the front....mama yama and her parts bin bikes! :lol:
    The PO told me they would fit the 700X, which was obviously incorrect, think he just wanted them out of his garage so....I dragged them on home.
