YICS blocking tool
Discussion in 'Hangout Lounge' started by fakeplay, Mar 26, 2012.
  1. fakeplay
    fakeplay Member
    Newburyport, MA
    Hi, How hot does that area of the engine get where the blocking tool is suppose to be inserted ? I've found some high-temp hose that will withstand 575 degrees, Just not sure if thats resistant enough. Thanks
    Anyone have an infared thermometer ?
    I suspect it gets a tad hotter than that. The YICS passages come out right behind the intake valves and air comes back up them from the intake ports where the valves are closed. I would guess that the YICS passage gets about as hot as the combustion chamber itself, or close to it. The combustion chamber temps in a typical 4-stroke internal combustion engine run 1500F~3000F according to WikiPedia. So going really conservative, I'd say 1000F? Inside the passage.
  3. Polock
    yeeooow, i dont think it gets that hot, those oil soaked rags wouldn't have a chance
    link
  4. fakeplay
    fakeplay Member
    Newburyport, MA
    1000 ? then what the heck were those guys using as block off tubing ?
  5. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    I believe your 575 degree tubing will work.
  6. TIMEtoRIDE
    I'm guesing lower -
    During a normal ColorTune session, with a fan running, at idle - 1,600 I would guess 375* F as a normal range and at 450 you would see and smell smoke.
    hey wait - I have a Laser Thermometer . . . (wait for it) :eek: :?:
