disabling petcock auto "on"
Discussion in 'XJ Modifications' started by bensalf, Apr 10, 2012.
  1. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    hi all,
    i am in the process of "cafe-ing" my xj 600. i wish to disable the automatic "on" feature of the petrol tap, or petcock as most of you refer to it.
    i've been through most of the threads, but ca'nt find the answer to this,
    if i disable the intake air line, and use the "petcock" to be on or off, do i lose the reserve facillity.
    or is there a way of blocking off one of the internal ports, to retain reserve.
    replacement "manual" taps are a bit pricey to ship to uk.
    cheers
    stu.
    "Reserve" is the same as "PRI" except it's vacuum operated and PRI isn't.
    "ON" is only "main" because it's standpipe in the tank is taller, so it runs out before it can draw from the last couple of inches of fuel in the tank.
    So unless whatever mod you make to it still allows the use of the two positions, ON and RES/PRI you'll lose the "reserve" feature.
  3. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Just remove the rubber diaphram inside, make a new gasket so it doesn't leak without the rubber, and plug vaccuum hole. You keep all function except off.
  4. Bushy
    Bushy Active Member
    And .. if you want OFF add an inline tap like on a lawnmower or such to what streetbrawler said and get used to using it.
  5. Osprey
    Osprey New Member
    Take your petcock apart an study how gas flows thru it. I was able to return mine to on-off-reserve normal operation (prime now being off) by flipping the lever and label plate upside down on my XJ700. The valve must remain closed or you can block off the hole with something.
  6. bensalf
    yorkshire ,england
    cheers all,
    so it seems there may be a way of retaining all features, i'll take the thing apart then and have a look. :lol:
    cheers
    stu.
    Hollybrook likes this.
  7. bensalf
    yorkshire ,england
    yaaaay, managed to dissable the auto on feature with your help especially the suggestion by "osprey" to flip the moving part over.
    [​IMG][/img]
  8. bensalf
    yorkshire ,england
  9. bensalf
    yorkshire ,england
  10. bensalf
    yorkshire ,england
    stripped the petcock and filed off the stop tab on the moving part to enable it to spin all the way round
  11. bensalf
    yorkshire ,england
    blocked off the auto on valve with epoxy putty
  12. bensalf
    yorkshire ,england
    this is the I.D plate "before"
  13. bensalf
    yorkshire ,england
    covered I.D. plate with body filler
  14. bensalf
    yorkshire ,england
    sprayed the plate with silver spray can and re-lettered the plate using" rub on" letter sheets.
  15. bensalf
    yorkshire ,england
    made thick rubber gasket and dicarded auto valve plate, and replaced rear cover.sorry for poor pictures
  16. bensalf
    yorkshire ,england
    clear coated the I.D plate, and re-asembled.
    so now there are two "off's" top and bottom
    "on"pointing forward
    "res"pointing backwards
  17. bensalf
    yorkshire ,england
    put dab of red paint on end of lever and clearcoated over, need to get an extra intake air hose blank to seal off the air inlet.
    job done, i hope
    cheers, stu.
