XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: Fishdoc
New Today: 0
New Yesterday: 0
Overall: 13293
Members: 3
Visitors: 65
Total: 68
Who Is Where:
 Members:
01: DaveT174 > Forums
02: luvmy40 > Forums
03: willingtowork > Archives
 Visitors:
01: My Account
15: My Account
19: My Account
20: Forums
21: Forums
22: Forums
23: Forums
24: Forums
25: Forums
26: Forums
27: Forums
28: Forums
29: Forums
30: Forums
31: Forums
32: Forums
33: Forums
34: Forums
35: Forums
36: Forums
37: Forums
38: Forums
39: Forums
40: Forums
41: Forums
42: Forums
43: Forums
44: Forums
45: Forums
46: Forums
47: Forums
48: Forums
49: Forums
50: Forums
51: Forums
52: My Account
53: Forums
54: Home
55: Forums
56: Forums
57: Forums
58: Forums
59: Forums
60: Forums
61: Forums
62: Forums
63: Forums
64: Forums
65: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
97317080
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Modifications › Hopefully this will be easy.
Custom mods for XJ Maxim/Seca...
Post new topic   Reply to topic   Printer Friendly Page    Forum Index XJ Modifications
Author Message
ryancdossey
Red Liner
PostPosted: Wed May 09, 2012 6:34 am    Post subject: Hopefully this will be easy. Reply with quote
I'm having an issue that someone on here has had to have overcame with a clever mod.
My mirrors shake to the point where I can't tell what's behind me.. and happened to be doing 75 mph in front of a leo for about 10 miles... Embarassed
Not only that but It makes it hard to judge what is behind me and how close... is that 40 feet away or much farther?
They vibrate (mainly on the highway)
like when you're in a car and have the radio cranked and the bass makes your rear view mirror "buzz".
Thoughts?
_________________
1985 Yamaha xj700 maxim x
15k original miles. Smile
Back to top
ryanrules
2nd gear
2nd gear
PostPosted: Wed May 09, 2012 6:55 am    Post subject: Re: Hopefully this will be easy. Reply with quote
Couple things I've learned over the years:
First, make sure all the engine to frame bolts are snug to spec. Wouldnt hurt to check the rubber isolation blocks either.
Next, and this is the one I like best, put lower bars on. The stock 70's and 80's 'bighorn' style bars aren't for me.
Check to see if your bike has vibration dampers in the end of the bars. usually a solid wad of metal. This helps on tall bars. Also check the tightness of the bars on the top triple clamp. Some have risers with rubber underneath that can rot out and let excessive bar movement.
I usually put low bars and bar-end mirrors on all my bikes.
_________________
1983 Yamaha XJ550RK
1972 Kawasaki H2 750 Triple
Back to top
View user's profile
Erman
6th gear
6th gear
PostPosted: Wed May 09, 2012 7:22 am    Post subject: Re: Hopefully this will be easy. Reply with quote
What Ryan says above +
Go for another ride, try to notice which speeds cause the vibration you mention.
- If it's a steady vibration, accross all speeds, check bolts, rubber dampeners, and wheels
- If the vibration occurs at high speeds, check your swing arm bearings, steering head bearings, check that the wheels are torqued to spec, and get your wheels balanced
_________________
1984 XJ750 Seca
Remaining work list 2011/2012:
SS brake lines, testing electricals, testing starter/live crank, Rolling frame test, 1st ride + Tune up
Back to top
ryancdossey
Red Liner
PostPosted: Wed May 09, 2012 11:29 am    Post subject: Re: Hopefully this will be easy. Reply with quote
I will check both of those when I get home. thanks for the suggestions guys. This is my first bike so my modification experience is pretty limited. How hard is putting lower bars on it?
_________________
Back to top
Orange-n-Black
XJ Wizard
PostPosted: Wed May 09, 2012 11:46 am    Post subject: Re: Hopefully this will be easy. Reply with quote
Had the same problem, filled the bars with expansion foam and used bar end weights. cut the vibration down about 80%.
_________________
Jack of all Trades; Master of None!
1985 XJ700N Maxim
My Build Thread
www.xjbikes.com/Forums...art=0.html
Back to top
ryanrules
2nd gear
2nd gear
Doing the bars are easy, routing the cables is where it gets 'fun'
_________________
1983 Yamaha XJ550RK
Back to top
View user's profile
ryancdossey
Red Liner
PostPosted: Wed May 09, 2012 12:13 pm    Post subject: Re: Hopefully this will be easy. Reply with quote
Ick!
and Orange. I'll look into that.
Yeah its a real pain not being able to use them fully.
_________________
Back to top
MercuryMan
XJ Wizard
PostPosted: Wed May 09, 2012 12:23 pm    Post subject: Re: Hopefully this will be easy. Reply with quote
Depending on how much you change the geometry of your bars, you might not just be able to re-route cables. I replaced my brake lines with SS lines and from the master C on the new bars to the junction was about 5-6 inches shorter. I had a custom line made since SS won't tolerate any twisting or excessive bending. The lower bars did really improve handling and my posture-and the look of the maxim IMHO.
+1 to all the above advice. Great idea to check all those points anyway for safety sake, and so you don't lose anything while riding. There are a number of options for bar stabilizing. BB's, bar-snake, foam, weights, etc. Your hands will thank you.
_________________
'81 XJ550 Maxim; 32.3k miles, Euro bars, slim-line blinkers, SS brake lines, 1/4 faring, extended blinkers, refurbished clocks
'81 XV750 Virago; 12.8k miles, Cobra Pipes, Saddle-bags-clutch adjusted, safety sw. fixed, bike runs! Carb work next
'81 XV750 Virago; 18.3k miles, 920 Tank & Pipes-likely parts bike down one cylinder
'93 Gary Fisher Tassajara - I know not a mc, but with me as the motor this little bike can fly! (my most modern 2-wheeler)
Prior Rides
'85 Honda CB650 Nighthawk-sold to pay bills
'84 Honda XL200-learned how to fly&crash on this monoshock beauty.
The obstacle is the path. ~Zen Proverb
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Warning light problem
Last post by luvmy40 in XJ Chat on May 23, 2013 at 05:02:05
Ted's '82 XJ750 Maxim Bobber
Last post by teddytedted in XJ Chat on May 23, 2013 at 04:48:11
Ted's '82 Maxim 750 bobber
Last post by teddytedted in XJ Modifications on May 23, 2013 at 04:38:48
XJ650 Maxim stalls when I shift to 1st
Last post by RickCoMatic in XJ Chat on May 23, 2013 at 04:37:45
painting over chrome?
Last post by razz1969 in XJ Chat on May 23, 2013 at 04:36:09
Seca/Maxim 550 differences?
Last post by Captainkirk in XJ Chat on May 23, 2013 at 04:31:55
Repainting, Tank Emblem Question
Last post by Mike82mxm in General Lounge on May 23, 2013 at 04:23:37
Craiglist SoCal '81 1100
Last post by Mike82mxm in General Lounge on May 23, 2013 at 04:19:28
Steering, Tapered bearings issues.
Last post by razz1969 in XJ Chat on May 23, 2013 at 04:18:27
Oil in swingarm/final drive help!
Last post by razz1969 in XJ Chat on May 23, 2013 at 04:09:03
