New project.
Discussion in 'Hangout Lounge' started by biggs500, Jul 2, 2012.
  1. biggs500
    biggs500 Active Member
    Sherwood WI
    1982 Max 750. 7900 miles. Why did they paint it like that?? With enamel!!! :x Oh well, another thing I get to fix. :)
    Overall it's in good shape. Of course I will be busy for a while making it truly road worthy. :D
  2. Wirehairs
    Wirehairs Member
    St. Paul, MN
    Gee, looks in real nice condition to me! I mean, minimal rust... Craigslist? Good price?
  3. biggs500
    Sherwood WI
    It is in good shape overall. It was laid down at one point so the tank has some small dings and obviously the carbs need to be rebuilt and valves checked and brakes gone over and...... You know, the normal 30 year old bike stuff.
    But again I really don't know what would compell someont to paint it with enamel. :?
    First things first though. Get it running and stopping right. :)
  4. patmac6075
    patmac6075 Active Member
    MKE
    Hey Biggs...I thought I saw that bike on CL...looked pretty clean? Looks like you have a nice bike there.
    Did I run into you at 5 corners gas station in Cedarburg a couple months back? If it wasn't you, some old dude is running around with a Seca that looks just like yours.
  5. biggs500
    Sherwood WI
    I know where Five Corners is but I wasn't there. And thanks on the Max. I'm looking forward to giving Len some more money. :D
    And yes, it was on CL. I low balled the guy and he went right for it. I should have gone lower still. :)
  6. biggs500
    Sherwood WI
    "Old dude"? WTF??? :) That make me laugh! I'm not that old.
  7. patmac6075
    MKE
    Ha ha,
    Well, it was an Old Dude (I'm 50+) on the Seca....now I'm glad to hear it wasn't you.
  8. biggs500
    Sherwood WI
    Well, I bought my Seca when I was 19. You do the math. :)
  9. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    Yeah, you're an old dude....sorry to break it to you. It was hard for me to accept too until I realized that it just means I can join the KMA club.
    LOL
    jeff
    BTW- your "project" looks better then most members bikes! And the enamel was for three reasons.....cost, bucks, dollars!
  10. biggs500
    Sherwood WI
    Little update:
    The shaft oil has been changed as well as the motor oil is drained. Why not refilled, you might ask? Take a look:
    The PO must have eaten spinach as the head was rounded and ultimately I had to use a Vise Grip to get the bypass bolt out. :x A new one is on it's way. Thanks Len. :)
    Also any suggestions on how to remove these? The mangled one in particular. They have Kroil on them now but will those 'Grabbit' type bits work here?
    Thanks for any input. :D
  11. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Tried the extractor method on my MC and it looked just like yours-didn't work. So I carefully drilled, using a tiny bit, the head of the screw into a nice long slot to fit a flat head into it. I then used a nice thin flat head driver with my vice grips attached to remove the screw. This of course was after soaking like you are. Be prepared for a nasty MC inside.
  12. biggs500
    Sherwood WI
    I used a small impact driver on the 'good' one and your 'drilling a slot' method on the 'bad one' and got it open. I don't know, looks all right to me. I think I'll button it back up and call it good. :D
  13. adrian1
    adrian1 Active Member
    Now you've got it off, order the allen head cover screws from XJ4EVER
  14. MercuryMan
    Springdale, NWA
    Good job, well I must say your MC looks better than mine did when I opened the crypt but still...
    30 minutes of Deepcreep, q-tips, and some sandpaper and...
    +1 to the Allen head MC screws they are exactly what was needed. Love em.
  15. bigfitz52
    OH NO YOU BETTER NOT.
    Dude, seriously? The bike is how old and has how many miles on it? It never sat?
    The original brake master cylinder and caliper seals had a factory-recommended lifespan of TWO YEARS. TWO.
    Now, I'll concede a certain amount of designed-in "safety margin." Whatever it might have been, 30 years is way past it.
    Rebuild that master cylinder. If it's in good shape, it'll be easy and cheap.
    Check the date codes on the (4-year lifespan) brake lines. Replace.
    And the date codes on the tires (6 years max.)
    Test the compression? Check the valves.
    You didn't buy this one new.
  16. MN-Maxims
    Fitz is right, replace all of the expired rubber goods and you'll be better off . But I must say you have a really great starting point there. We have seen a lot worse and those were brought back with many hours and big bucks to make them right.
  17. biggs500
    Sherwood WI
    No,no,no. That was a joke. Rebuild kits and SS lines are in the very near future. Before riding it. :D
  18. MercuryMan
    Springdale, NWA
    It's all good biggs! I saw your smiley face and was pretty sure you were joking. That's why I only nudged you with my MC picture. The problem is that not everyone would be. Fitz has seen too many be lazy and not take their bike seriously. How many times has someone been given good advice only to ignore it thinking that it's just too much work.
    My personal feeling is that brakes can NEVER fall under the I'll take care of it later category......Dang I'm gonna go check mine over right now!
  19. biggs500
    Sherwood WI
    I did go with the Allen head screws. I switched my 650 to those last year when I did those brakes. So much nicer.
    I want to apologize if I mislead anyone with my "looks all right to me" comment. :oops: Sorry about that. I do want this thing to be able to stop and truly do appreciate the concern. :)
    As far as checking the compression I would like to do that (on my 650 also) but I need to pick up a gauge first. Who makes a good gauge? I probably already know this answer but are the Harbor Freight ones worth anything? If not, any recommendations?
    The picture below is just to show the Allen head screws. It's nowhere near ready to be ridden yet. I just have the cover back in place (with a few fresh scratches).
  20. biggs500
    Sherwood WI
    Nice paint job. Both of them. :( The ugly blue underneath feels awfully soft as well. Nothing like two layers of the wrong paint. I don't think that was ever a factory color, was it? I only remember black and red.
    Carbs are off ready for a though scrubbing and hopefully the new o-rings, seals, gaskets,ect... will be here tomorrow. :)
    Looks like this was hit by a drill bit or hard to turn at one time. At least it turns. This will need to go.
  21. biggs500
    Sherwood WI
    That messed up idle mixture screw had me a bit worried. As I was turning it out it became more and more difficult to turn. Finally came out though. I'm going to replace it with one out of a spare rack I have. The spare is from a 750 and has the brass screws also. It fits and they both look the same. Any reason it wouldn't work?
    My safety glasses also got a nice blast of carb cleaner. 8O That's why we wear them. :D
    Here's one dirty emulsion tube. The jets were similar. So far I've only broken into one carb. I'm done for today, too darn hot.
  22. biggs500
    Sherwood WI
    The PO said the tires are new and they certainly look it. the last two digits on the date code are '12'. If I read that properly that's 2012. Correct?
  23. biggs500
    Sherwood WI
    Clean. And all the holes are open now.
  24. biggs500
    Sherwood WI
    Got to cleaning the last carb and this is the float needle that was in it. Amazing.
  25. JeffK
    LOL....I just spit coffee all over my office......holy crap,....Fitz, he's joking!!!
    Tha't what the "joking smiley face" was meant for!
    Now you've done it Biggs.....you'd better get in here and fix this<LOL>!!
    Sorry, had the page resized and didn't see that you had already told them.....
    jeff
  26. biggs500
    Sherwood WI
    The Motion Pro tool in action!!! Now to order some shims and brake lines and rebuild kits. Getting closer. :)
  27. biggs500
    Sherwood WI
    Clean! New seals and o-rings. Ready to go back on the bike. After I put the 'choke' hardware back on of course.
  28. mtnbikecrazy55
    Wowzers! Can't wait to get mine looking that good! :D
    I'll be back in wisco in a week!
    Bike's looking great, that paint job is bonkers!
  29. biggs500
    Sherwood WI
    New plugs, ready for action.
    Carbs are on, Now to put those PIA air box to carb boots. They're a heck of a lot easier on the Seca.
    Got it all together and it fired right up. :D SS brake lines shipped today as well. Should see those early next week.
  30. biggs500
    Sherwood WI
    I'm going to replace the headlight just so I know there's a good one in there and I find these two wires not connected to anything. Everything seems to work so any idea where the go? Thanks.
  31. ski84
    ski84 Member
    New Mexico
    I believe those are for fairing lights. All the 750 Maxims have that extra pair of connectors that are in parallel with the head light plug.
  32. biggs500
    Sherwood WI
    Any guess as to which one is new?
  33. biggs500
    Sherwood WI
    Now this looks much better. New sight glass too. :)
    Red SS lines.
  34. biggs500
    Sherwood WI
    Opps, I see I need to reroute my speedo cable.
    Edit: Strike that. I think that's correct for the brake line to be on the outside.
  35. biggs500
    Sherwood WI
    Got it running good and smooth. Now I'll start on some cosmetic issues. Gasoline works really good removing the paint from the tank.
  36. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Nice!
  37. biggs500
    Sherwood WI
    Well it's been a while. Still haven't put the battery in from winter but I did get the 'new' headlight bucket I got off eBay painted.
    Here's the original headlight bucket. Still looking for an instrument cluster housing.
  38. biggs500
    Sherwood WI
    No more black painted duct tape on the busted up instrument housing. I found one at a local salvage yard with much less damage. Some fiberglass repair on the inside and JB Weld on the outside as filler and it's just like new. :) Almost.
  39. cutlass79500
    lawrenceville georgia
    Doing a great job. I bought my maxin 750 used and liked it a lot in 83 traded in on a seca 900 a year later. I got a great deal on a seca750 leftover in 85 for $1800 but i liked the maxim better maybe i was spoiled from the 900 but the 750 just did not do it for me at the time ended up selling it for what i paid for it and bought a litre bike. Back in the 80s was on a more power trip lol
  40. biggs500
    Sherwood WI
    These were a bit of a pain to separate.
    After first coat of Aircraft Stripper.
    Can you tell which one I used Lemon Pledge on?
  41. biggs500
    Sherwood WI
    Now why was this painted? :? The chrome is in very good condition.
    Time for some stripper.
    Doesn't take long.
  42. biggs500
    Sherwood WI
    Time for a little distraction. My Seca clock.
  43. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    Yeah, found that out last summer when I was distracted at the filling station. Darn red heads in tube tops!
  44. biggs500
    Sherwood WI
    Grab rails, one polished, one not.
    Both polished.
    Since I'm painting it yellow I thought the black stripe should be yellow too.
    Polished with a yellow stripe.
    Here I just put the tank on to get a picture of what it will look like. I want to let the paint harden for another week yet before I put gas in it. Still lots to do. I might need to revisit the side covers. I'm thinking going back to black on the bit that shows above the aluminum frame and the part that shows below the right side frame. We shall see.
    XS 650 badges to be put on yet. I will have to put a dummy screw in the holes.
  45. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    looks great Biggs!
  46. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    Those engine guards look awesome !!
    Really makes the bike pop !!!
  47. biggs500
    Sherwood WI
    Hmmm....I wonder who put me on to them? :D
  48. biggs500
    Sherwood WI
    Did the rear brake tonight.
    And finally a splash of color.
  49. ElkHavenSeca
    Sedro woolley wa
    What method are you using to polish those so nice ??
  50. biggs500
    Sherwood WI
    Elbow grease. First strip off any factory clear coat and then a dry 220 grit sandpaper followed by a wet sanding with 400,1000,1500 and then 2000 grit. Finish it off with metal polish. I've been using Magic Mix. Works good.
