82 maxim 1100xj rear wheel locked up at highway speed...why?
Discussion in 'XJ Technical Chat' started by jssepaterson, Jul 27, 2012.
  1. jssepaterson
    jssepaterson New Member
    Alberta, Canada
    Not sure why yet, anyone know of a reason this might happen? Haven't looked into it yet, still recovering. Wondering if the gear oil resevoir was low/empty? I don't know how to check it.
    I'm new to all this and am kicking myself for not reading my manual thoroughly and knowing my bike better.
  2. Sabre
    Sabre Member
    Lansing, MI
    Probably because one of your rear brake shoes delaminated. It's a known issue with the original brake shoes. http://www.xjbikes.com/Forums/viewtopic/t=15874.html
    If you don't even know how to check the oil in the final drive you don't have any business riding a 30 year-old motorcycle. There is a lot of maintenance that needs to be done to these old rides to make them safe put on the road again.
    Read up here and in your manual until you feel more comfortable doing some maintenance yourself. These are some things you should check:
    1. Replace rear brake shoes so you don't experience the delamination issue (too late)
    2. Check date codes on brake lines. Odds are they're original and need replacing.
    3. Replace the 30 year-old seals in the caliper and master cylinder.
    4. Check the date code on the tires and replace them if they are over six years old.
    5. Inspect the valves for proper clearance and adjust as necessary.
    None of this is particularly hard. I have no mechanical training and with a manual and the write-ups here I was able to do most of the above with no major issues.
  3. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Howdy, sorry to hear of your misfortune. Low or no gear oil should not cause a lock up situation, my best guess would be something to do with your rear brake. Did the lock up occur when you applied the brake? But to answer the question about the final drive oil level; there is a plug you can unscrew with an allen wrench, the oil should be to the top of the threads in the hole.
  4. rhys
    rhys Member
    Columbia, MO
    There's so little oil in the rear that you don't really check it so much as you either change it outright (it only takes a couple of ounces) or you put it on center stand and open the screw cap (points up and back, not the thing that points straight up) and make sure you see oil almost overflowing out of it.
    I confess not to know a heck of a lot about the way the final drive works. I do know that the oil I drained out of the back of my 650 was *greenish-black* when I first got it. New gear oil is golden. Who knows how long it had been in there.
    In your case, start by changing that oil and then dismounting the rear wheel and look for obvious damage in the wheel and the hub. When you get the wheel off (it pops off of the hub by sliding to the right), you'll see where the wheel and the final drive meet and whether or not there are bent metal bits in there.
    Does the rear wheel turn freely if the transmission is in neutral? Does the engine idle? While I don't recommend this under most circumstances, can you put the bike on center stand, start it, put it in first (ENGINE IDLE ONLY) and get the rear wheel to spin relatively smoothly?
    It will buck a *little* since the wheel is turning with no load, but you should be able to just stand there and watch - it's mesmerizing - without obvious concern. If it's doing *anything* that seems like cause for alarm, kill switch! Definitely don't let it get off of that center stand while in gear! Maybe run this test while sitting on the bike with front brake engaged and a helper to observe the rear wheel.
    Sorry that's not more helpful.
    [EDIT]: After reading the other replies, I guessed right(-ish). You'll be able to get at those rear brakes once you have the rear wheel dismounted. Pay careful attention to the brakes and keeping things clean where appropriate as you re-assemble them. Brakes keep you alive. Lube the pivot point, and ONLY the pivot point. Friction surfaces should be as clean and oil-free as you can get them with brake parts cleaner. Get this one right.
    [EDIT 2]: For disc brakes, dismount the caliper and see if the rear wheel spins freely and the other tests I mentioned pass. If so, time to rebuild the rear brakes. Caliper probably seized, but you should check it stem to stern.
  5. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Sabre, the XJ 1100 has a rear disk brake, delamination is not an issue. Rhys, there is more than a pint of gear oil in the final drive, and it should be checked at least once a year.
  6. jssepaterson
    Alberta, Canada
    One of the guys that stopped to help touched the rear brake disc and said it was cold so it wasn't the brake.
    I know I need more information. I really felt like an idiot for all the unknowns I should know!
  7. midnightmoose
    midnightmoose Member
    York, PA
    The xj1100 has a rear disc brakes so no shoes to come apart. Sounds like your piston seized up in the caliper or something along those lines. Might have something to do with the bike being 30 yrs old...the seals in the calipers are only good for 2 yrs and were probably never replaced.
    Glad to hear you're still around to tell us about it.
  8. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Another possibility is that a chunk of metal got between your ring and pinion gears and that would be very bad, but the chances of that are so remote.
  9. Sabre
    Sabre Member
    Lansing, MI
    It won't generate heat since it's not slipping. It's locked. Take the rear wheel off and look at your brake shoes. I'd bet money one of them is delaminated.
  10. jssepaterson
    Alberta, Canada
    And even though I don't know near enough i have had it safetied, worked on by 2 bike mechanics, who with me replaced the whole motor and clutch assembly...I've tried to be safe with it but after my first long ride (3 hours up and 3 hours back....though the accident happened about half way home 3 days after my original trip up :) I realized there is still lots more to know that can be life or death important!
  11. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    After some thinking about it, I believe that when you applied the rear brake the piston seized and not gradually either. This would explain the cold rotor.
  12. rhys
    rhys Member
    Columbia, MO
    No one is born with knowledge of how to do anything besides eat, poop, and complain. What differentiates us is how we react to a situation where you suddenly need to know more. Do you go find out? Or do you fake your way through (meaning shortcuts)? Or do you give up?
    The third kind sell bikes to me. The second kind get themselves killed and I get their bikes from the estate sales. The first kind get to ride with me and have munchies afterward and talk smack about themselves.
    Don't feel bad about not knowing. You should only feel bad about CONTINUING to not know. Your presence here is a good sign. Keep after it until you're satisfied that you know what caused the problem and that you know what you need to know to maintain this bike. It doesn't take long to understand all of its systems and what each one requires, and just about everything you need to know is on here. Stick with it and, as one of my parts suppliers put it, "Get out there and shred the pave." :p
  13. jssepaterson
    Alberta, Canada
    I will get into the bike as soon as I can use both hands...but I was in the process of passing fairly slowly--not really increasing speed but slowly passing a car, wasn't braking on purpose...then if I recall correctly I felt an initial sudden grip and then the fishtailing started (continued for about 200feet and then we went down)
  14. Sabre
    Sabre Member
    Lansing, MI
    Oh, whoops. Well now I know :D
  15. jssepaterson
    Alberta, Canada
    or rather...wasn't braking at all, just a nice leisurely cruise and then it grabbed.
  16. mlew
    NO that is yoo much. On the XJ1100 there is a special tool to check the oil level. It is included in the tool kit. The correct level is actually about 1" below the fill hole. That same tool is also used to check the middle drive gear oil level.
    Since you had a sudden wheel lock-up it is probably not the brakes, though it is possible. A few things it could be; rear drive or middle drive gear boxes, drive shaft U-joint, transmission. Any one of these can cause sudden wheel lock.
    Time to put the bike on the center stand and have a look.
  17. MiCarl
    Re: 82 maxim 1100xj rear wheel locked up at highway speed...
    When I started reading the thread my suggestion was going to be the brake. Some of the other info (especially the cold rotor) seem to rule it out.
    Not sure what else can "grab" the rear wheel without things breaking though. Be interesting to hear how this turns out.
    Sounds like you weren't real badly hurt. Glad to hear that.
  18. adrian1
    adrian1 Active Member
    I'm putting my money on catastrophic failure of the universal joint.
  19. MidnightSmoke
    MidnightSmoke Member
    Dahlonega GA
    Had 2 of the 4 bolts that join the middle gear flange to the universal joint back out on me one time. Instant rear wheel lockup!! Lesson learned?...check everything on these bikes. PO had not used Loctite on the bolts and I can only guess how close he came to torquing them correctly. Even though they all now have Locktite and proper torque, I check them on a regular basis just like any other maintenance item.
  20. OzRoadbandit
    OzRoadbandit Member
    was the motor still running or did it seize ? if it did seize, what caused it ?
    Catastrophic gearbox failure ?
    Universal joint failure ?
    Diff failure ?
    brake lockup ? but doesn't sound like it....
    photos and a strip down to help solve the mystery ..... glad to hear you're still in the land of the living though.
  21. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Thanks for the correct info Mlew, I was not aware the XJ 1100 was so different from the other XJ's
  22. smurf667
    smurf667 Member
    Newark, Nottinghamshire, England
    It shows that you don't know the bike either, as the 1100 has got discs, not drum brakes
    Excuse me???? What exactly gives you the right or authority to make a statement like that, especially to someone asking for help and is new on here, remember, we ALL had to, and have to learn things about these bikes. How do we learn??? most of the time either by reading up or asking for help.
    It was totally uncalled for.
  23. smurf667
    smurf667 Member
    Has anybody even considered seized wheel bearings?
  24. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    That was my guess also smurf667, I was just reading the post and thought the same thing. Put the bike on the center stand, remove the rear brake shoes and try rotating the wheel. The go from there, checking everything back towards the motor/transmission.
  25. LayItDown
    LayItDown Member
    Montgomery, AL
    im going with the u-joint also. i find it very hard to believe if the caliper locked up it would instantly and completely lock up that wheel. so you would have some pretty nice scars in the rotor. probabkly can rule out wheel bearings too since the axle would still spin even if the beared colapsed or locked up.
    throw thing up on the center stand, grab a beer, a manual, and turn a wrench. should be pretty simple to figure out the problem. even if you have never seen the inside, you should be able to tell what went wrong. and its far simpler than you would think.
  26. jssepaterson
    Alberta, Canada
    Wow bit overwhelmed with the possibilities but excited to get my hand back in working condition...
    (apart from some minor scrapes, a severely sprained wrist/hand was all that I got--i am very happy to be alive as it really should have been much worse) ...to get all these different things taken apart and Looked at. I will take Pics and when I do should I just post them under this topic heading? I'm sure it will be at least 2 week before this happens. And thank you for the encouragement and advice, you've no idea what that means to me--or maybe some of you do :)
  27. LayItDown
    LayItDown Member
    Montgomery, AL
    Kinda off topic, but did you have on any riding gear when you went down?
  28. jssepaterson
    Alberta, Canada
    I had actually made the trip to pick up gear, went up in too big riding jacket and jeans to pick up a set of riding pants and jacket that were waterproof and padded, actually my size etc. lucky i wore them home and i will never ride without proper gear again after that scare. It saved my literal hide. Didn't even get wrecked just tore at the seam on the one arm where the big area of padding is...but it should be easily repairable. I'm still not sure how I actually landed. My bike is scuffed on the left (tank, windshield, pedal, front turn signal) my right arm has scrapes up it and that arm of the jacket was the one that tore and my left wrist and hand is sprained....and my left glove (not a proper set if riding gloves) has some scuffing on the palm. Wish someone had caught it on video!! Apparently the car behind me did some creative driving to avoid me.
  29. jssepaterson
    Alberta, Canada
    Scuffed on left
  30. jssepaterson
    Alberta, Canada
    I honestly don't know if the engine siezed....I remember trying to gear down and keep the bike upright not sure of anything else
  31. MiCarl
    If the engine is seized the rear wheel should turn when the clutch is pulled. That will be the first thing to check.
    I'm assuming you pulled the clutch when you attempted to downshift. If the engine was seized and you did that it probably resulted in a high side crash. If so, you're extremely lucky not to have severe injuries.
    I think if the bearings seized the axle would break. Catastrophic U-join failure or coming loose from the middle gear flange could sure do it.
  32. MN-Maxims
    He will have to get it up on the center stand and we can go from there.
  33. TIMEtoRIDE
    No offense my good friend, but 180,000 PSI strength VS a 500 LB load at the tire ?? The axle would not snap. The bearings would make noise before failure.
    I'll be the odd-man-out and guess some debris jammed-up the tranny gears, as all the other good guesses are taken.
    A driveshaft failure (including "U" joint) is a good guess.
    jssepatterson - mend well and ride safe !!
  34. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Well! I think we have exhausted all the possibilities. How about this one... A big-rig is carrying fence poles and makes a sudden stop just as our poor rider is going by, and one of the poles slides off the truck and just happens to go right into the rear wheel...I'm glad to hear that you are ok, we just need to lighten up a bit. Please get back to us on what the problem turns out to be.
  35. MiCarl
    No offense taken. Your challenge did cause me to do the math. Looks like at most a seized bearing would put under 500 ft-lbs. torque on the axle. Probably not enough to break it. :cry:
    Apparently failing bearings aren't always heard. There was a guy on the STAR Touring forum that had the swingarm on his V-STAR 950 snap when a wheel bearing seized. The tail of that swingarm is cast aluminum though. Somehow he managed to keep it upright to a stop.
  36. WileyDan
    WileyDan Member
    Rochester, MN
    Glad to hear your still around to figure out what happened. I wish you a quick recovery and look forward to hearing the final verdict on what happened.
  37. mtnbikecrazy55
    X2. Glad you're okay!! It will be interesting to see what the culprit was!
  38. TIMEtoRIDE
    [quoted from "Coldndead" from "The Bunny" thread - -]
    . . .my friend died because he had tied a coat on the back and a sleave,yes only the sleave came loose and found the spokes of his rear tire. at 65mph ...well....you can figure out the rest. . .
    WOW - just takes a jacket sleeve to stop a rear tire - - Ride Safe !!
    jssepaterson - so what happened anyway ?? We got bets going :lol:
  39. jssepaterson
    Alberta, Canada
    Sorry I am away from home at a family reunion so no bike work yet but I will post results and pics when I start! i can't wait to find out myself. Thanks again for the suggestions I now have an idea what things to look for
