Brake Fluid
Discussion in 'Hangout Lounge' started by tumbleweed_biff, Mar 7, 2013.
Have you replaced your fluid in the last two years?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
  1. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    I was at the auto parts store and asked the sales people about brake fluid - using Synthetic or the traditional stuff - which whether synthetic (DOT 5) fluid was better than DOT 3 & 4 & 5.1. They didn't have an opinion as to which fluid was better or why and I ended up going with DOT 5 thinking it would be a higher standard of fluid ...
    This is NOT a good idea. DOT 3/4 & 5.1 fluid is not compatible with DOT 5. When the two get mixed they congeal into something not very brake friendly. Basically, there are two things to know: First: don't use DOT 5 fluid unless you completely clean out all traces of DOT 3/4/5.1. Second, replace your brake fluid every two years, not just for your bike, but for your cars too unless you are using DOT 5 fluid, in which case you need to replace it ANNUALLY.
    For a full detailed explanation, I offer the following web article - text copied here in case the other site goes off line:
    http://www.motorcycleproject.com/motorc ... fluid.html
    This topic has always been a hot one, D.O.T. 3 brake fluid versus D.O.T. 4, versus D.O.T. 5. Which is best? Isn't D.O.T. 5 the hot set-up? Why are there different kinds to begin with, and what are the pros and cons of each? Let's explore all that, and hopefully in the process eliminate the hype and misinformation that often surrounds this subject.
    Air? From Where?
    Let's begin at the beginning. A brake system is not a sealed system. A physics principle known as Boyle's Law in a round-about way establishes that a fluid cannot leave a container unless air can follow it. If the vent in your gas tank plugs up, for example, fuel will eventually stop flowing. Similarly, a brake system is, like a fuel tank, vented to atmosphere, usually at its highest point, the reservoir. (Ever notice that little notch?) Thus a brake system has continuous access to air.
    The Problem with Moisture
    But that means it also has continuous access to moisture, for air naturally has moisture in it, to varying degrees. All brake systems have moisture in them, all the time, and this is unavoidable. There are two inherent difficulties with this that brake system designers must contend with. First, as moisture increases in the brake fluid, it tends to collect around the system's moving parts, particularly the pistons. If this moisture is allowed to increase, the pistons and surrounding areas will begin corroding and brake function will be seriously impaired. Corrosion is a big deal in brake systems, as anyone who has restored a vintage vehicle will attest. Nasty.
    The other problem with this continuous exposure to moisture is that moisture makes the brake fluid more compressible. You don't want any compressibility in a brake system. For every millimeter that the lever or pedal moves, you expect a proportionate movement of the brake pads against the disc. If you don't have that, you have an unreliable and dangerous brake system. Unfortunately, brake fluid becomes more compressible as it increases in water content. Water contains hydrogen, and in response to heat cycles the brake fluid soon has air mixed into it as well as moisture.
    Consumer-Friendly Brake Fluid
    Brake system designers consider these issues thoroughly. To reduce the effect of both corrosion and compressibility, virtually all vehicle manufacturers use and specify a kind of brake fluid that is designed to not only accept significant amounts of moisture, but even to neutralize it by dispersing this moisture evenly throughout the system, thus preventing its concentration in any one area. It's actually kind of amazing what brake fluid does, when you think about it.
    What Does the D.O.T. Rating Mean?
    Eventually, however, because of this designed-in moisture management, the fluid gets overloaded and must be replaced. So important is this fluid replacement point that vehicle manufacturers have traditionally called for a maximum of a two year period of use of the fluid. By that time, the fluid will have started to turn golden, then light brown, indicating that it has absorbed progressively more moisture. Eventually, if left unchanged beyond the recommended service interval, the fluid will become dark brown, indicating high amounts of water absorption and thus badly contaminated fluid.
    The importance of monitoring brake fluid's water content is further demonstrated by the fact that in the U.S., a brake fluid's most important classification is determined by the Department of Transportation, an arm of the National Highway Traffic Safety Administration. The D.O.T.'s rating communicates how contaminated with water the fluid can be and still work properly. In essence, how consumer-friendly it is. This is where the numbers 3, 4, and 5 actually come from. The D.O.T.'s rating focuses on the compressibility issue, and measures a brake fluid's ability to resist boiling into a very compressible gas even when new. This of course reflects upon its compressibility over time as well, after it has aborbed moisture and become incrementally more compressible. This is the fluid's so-called boiling point, which for most brake fluids centers around nearly 500 degrees Fahrenheit when new, and rapidly decreases with water content.
    Incidentally, D.O.T. 3 brake fluid is for all practical purposes obsolete. D.O.T. 4, a rating that came about in response to the emergence of sintered metal brake pads during the early 1980s, has replaced it, being still a glycol fluid but with a slightly higher boiling point. Glycol brake fluid containers now are labeled "D.O.T. 3/4," presumably to eliminate confusion, as the two fluids are nearly the same. However, this seems to have merely raised more questions in most people's minds. The short of it is, if using purely organic (almost exclusively aftermarket, and usually, racing) brake pads, D.O.T. 3 will suffice. Otherwise, use D.O.T. 4.
    Glycol Brake Fluids
    Virtually all vehicle manufacturers specify one kind of brake fluid, whose base is alcohol. As we have already explored, this eminently ubiquitous alcohol (actually glycol) brake fluid is suited to the realities of vehicle ownership. It neutralizes moisture, turns color in direct proportion to moisture content, disperses moisture so that it doesn't concentrate, and resists heat related degradation that leads eventually to increased compressibility. Glycol brake fluid is clearly extremely forgiving, maintenance-wise. In fact, vehicle manufacturers use it because they are quite aware that the average owner will never change his brake fluid, let alone do so at the recommended maximum two-year intervals!
    There are disadvantages to glycol brake fluid however. For one thing, the very attribute that enables it to accept moisture actually causes it to attract moisture, as any alcohol product will. For this reason, brake fluid suppliers recommend that only small amounts be kept on hand, and that a tight seal be kept on any unused fluid. (In the old days, it used to be available only in metal cans.) Another disadvantage, and a significant one, is that glycol fluid is chemically caustic, meaning that it damages other materials. It effortlessly removes paint and does strange things to plastic. (Even after it is wiped off, glycol fluid causes catalytic embrittlement, a chemical reaction on the molecular level that leads quickly to deep cracks. The ABS plastic used in motorcycle bodywork is especially susceptible.)
    Silicone Brake Fluids
    In years past, all brake fluids were glycol. Then D.O.T. 5, a silicone fluid having a higher temperature rating, emerged, initially to meet the higher boiling point requirements of racing use. (Race car brake systems include oil-cooler-like heat exchangers and ceramic pads.) Silicone fluid was able to withstand the most heat of any brake fluid, so it earned a reputation as a racing brake fluid. However, silicone brake fluid has properties very different from glycol fluid, and has its own pros and cons. On the advantage side, silicone fluid will not harm paint or plastic, and does not aggressively attract additional moisture as glycol fluid does. On the disadvantage side however, silicone fluid aerates easily. Harley-Davison, one of the sole current OEM users of silicone fluid, warns buyers to let the fluid sit at least an hour before using it. The trip home in the saddlebag is enough to aerate silicone brake fluid until it looks like a freshly poured soft drink. Silicone fluid is also slightly more compressible than glycol fluid, does not change color to tip the user to its moisture content, and worst of all, neither accepts or disperses moisture, making systems using it more corrosion prone, and requiring much more frequent fluid changes. Silicone brake fluid also lacks glycol fluid's naturally occuring lubricity, making it incompatible with the mechanical valving in some antilock braking systems.
    A third brake fluid category could be included, if we were to consider bicycles. Their hydraulic brake systems use mineral oil, that is, baby oil. About the same consistency as glycol fluid, mineral oil is still not the best thing around paint, but in most other respects it is fairly non-corrosive. Like silicone fluid however, it does not deal well with moisture.
    Which is Best?
    As you may have noticed by now, instead of looking at brake fluid as D.O.T. 3/4 versus D.O.T. 5, we should see the issue as glycol versus silicone. This represents the larger division of type, and comparing D.O.T. ratings just isn't significant, especially since D.O.T. 5 fluids are now available in glycol formulation. Glycol fluids have improved until they now meet D.O.T. 5 standards. D.O.T. 5.1 for example, is a glycol fluid designed for certain ABS systems having mechanically cycling proportion valves. So now we have D.O.T. 3, 4, 5, and 5.1, with all but the 5 designation being glycol, while the 5 is silicone.
    The real way to compare brake fluids is by deciding what is important to you. Is silicone fluid's safety around paint and plastic more important than yearly changes and a softer action? Its higher boiling point, the reason for its development and at one time its strong suit, is now academic, since D.O.T. 5 glycol (5.1) fluids are now widely available. Glycol fluid therefore is, for most of us, the better brake fluid, and the best just may be the 5.1, if the highest boiling point, which is really a moisture tolerance measurement, matters.
    On the practical side, beware that glycol and silicone brake fluids are hugely incompatible with each other. Mixing even small amounts will create a sludge that looks amazingly like Italian salad dressing and is about as effective as a brake fluid -- meaning, not. Of further consideration is that, in some cases, the hardware designed for one fluid will not accept the other. Brake caliper and master cylinder seals, hoses, and other parts won't always work correctly when the type of fluid is changed.
    Summary
    Over the years, the debate has continued as to which is the best fluid. Racers and custom builders have traditionally promoted silicone fluid, and many street riders have assumed this meant it was good for them also. However, silicone is the highest-maintenence of all brake fluids, one that demands frequent attention. While this is acceptable in a race setting, it is less so in everyday commuting. The plain fact remains that vehicle manufacturers use glycol fluid because, with its being designed for the average consumer, it poses the least liability to them. In reality, the answer to the usage question is simple -- the brake fluid type the manufacturer recommends is the best. In most cases this will be the glycol fluid, the one that is designed to meet all of your brake system's demands and do so with very little fuss.
    Mike Nixon
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Best for stock bikes is 5.1 IMO, it's the latest spec mineral fluid. The dot5 can in some cases cause trouble with older seals etc from what I've read in various places, on top of the non-compatibility issue with any trace of mineral fluid.
    Only scanned thru O/P so if I'm repeating anything sorry
    Also, the synthetic fluid has less "feel" and slight sponginess compared to fresh 5.1.
    This being said, our bikes will happily run the minimum DOT number originally spec'd with no problem/safety downgrade at all provided it's clean & fresh and changed regularly (as per any mineral fluid)
    Main issue for these age bikes is the age of the rubber components of the hydraulic system, as many still have 30+ year old pipes that are degraded internally and potentially perished seals.
    I haven't actually changed the fluid *yet* on the XJ, but there's no point just now since it's off the road & I'll be replacing the hoses & seals as a matter of safety before putting in for the MoT anyhow. I'll likely use DOT5.1 or 4 fluid.
  3. quebecois59
    Wow, that is information! Thanks a lot!
  4. MiCarl
    DOT 5 has two advantages over the Glycol (DOT 3, DOT 4, DOT 5.1) brake fluids:
    1) It doesn't harm paint.
    2) It performs better at extreme temperatures. The military likes this because they can move their tanks from the Sahara to the Arctic circle without worrying about the brake fluid.
    DOT 5 is absolutely incompatible with any other brake fluid. It reacts with the glycol fluids to form sharp little crystals that wear parts and cut seals.
    DOT 5 likes to mix with air so it has to be installed carefully.
    DOT 5 will not absorb water. While in some ways that is a benefit, any moisture that enters the system ends up laying in the bottom of the calipers where it will cause corrosion. DOT 3, 4 and 5.1 absorb moisture (turning dark when as they do) so when you flush out the fluid the moisture goes with it.
    Bottom line, unless you've got a system designed for DOT 5 or have retrofitted a show car where you're very concerned about the paint you're best to stay well clear of it.
  5. tumbleweed_biff
    Gahanna Ohio
    Another major disadvantage to DOT 5 is the need to be replaced annually instead of every two years.
    The main points I wanted to get across: unless you KNOW that your brake fluid has been completely replaced with DOT 5 synthetic, don't use it. Only use the glycol based DOT 3/4/5.1 AND that your brake fluid needs to be replace every two years.
    Yamaha said to use DOT3; that's what I use.
