Something missing on the back side of my calipers?
Discussion in 'XJ Technical Chat' started by Heyitsme, Mar 11, 2013.
  1. Heyitsme
    Heyitsme Member
    Seattle, wa
    Is there suppose to be some kind of covers for the back of these brakes or is this normal? Oh, and what are those things sticking out of each caliper?
    Which bike is that?
    Yes, there should be plastic covers. On some calipers they screw on, on those they appear as though they just snap on.
    The things sticking out? You mean the bleed screws?
    You need to replace those brake lines. Read this: http://xjbikes.com/Forums/viewtopic/t=41400.html
  3. MiGhost
    MiGhost Well-Known Member
    The sumitomo calipers were used on the xj700's, and no they did not use a cover over the pad clips.
    Everything looks pretty normal there. I do agree with fitz about replacing the lines though.
    Ghost
    I looked in the XJ900RK fiche; the calipers appeared to be very similar to those pictured and they have a snap-on cover; it appears to engage the slots that are visible in the pic.
    I couldn't find any others that looked quite enough like the pic.
  5. johnnyx
    johnnyx Member
    london ont
    My xj750xn has the same calipers and there are plastic caps that go on there as dust caps.They just clip on.
  6. RickCoMatic
    Those Covers often just pop-off when you ride over railroad tracks.
  7. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    plastic caps just clip on, on the 600
    stu
  8. 750E-II_29Rbloke
    South Cheshire, UK
    Wow, bike's a '91 but that brake pipe looks like it says '78 :? 8O
  9. MiGhost
    The 900RK used the blender spoke wheels with single piston calipers. The wheel in the picture would be the 5 spoke used on the 85-86 XJ700's, and 84-85 XV700 virago with dual piston calipers.
    The parts schematics do not show a dust cover used on the calipers. Wouldn't be the first time that a manufacturer used an unidentified part.
    Ghost
  10. bensalf
    yorkshire ,england
    nah, that first digit is a backslash
    stu
  11. bensalf
    yorkshire ,england
    plastic cap is on bench, at back of caliper
    stu
  12. quebecois59
    This is the best shot I have of the calipers caps of my Seca 900RK, my calipers are obviously not the same model as Heyitsme:
  13. MiGhost
    Could you check to see if there is a part number on those dust caps. They are also not shown in the parts schematic.
    Ghost
  14. bensalf
    yorkshire ,england
    Ghost
    will have a look in morning, its almost 2am now,
    oh ,it is morning
    off to bed
    nighty night!
    stu :?
  15. hogfiddles
    MiGhost, if you don't get a part number after awhile, I'll check through mine and see if there's one there.......
    Dave F
  16. Heyitsme
    Heyitsme Member
    Seattle, wa
    Mines a 85 700 so it looks like it had covers at some point then huh, but if it doesn't hurt to leve them how they are then that's what I'll do.
    I didn't know the 5 spoke wheels only. Came on the 85 and 86's, I love these wheels! I'm in the proces of reprinting them too, I'll post a pic when I, done
  17. johnnyx
    johnnyx Member
    london ont
    I will check my caps for a part number and let you know later-they are just to keep rocks and dust out-i actually just lost one on the weekend and i am going totry and get chrome ones for my bike.
  18. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    There's definitely supposed to be covers there.... if you can't find em..... hit me up. I have a spare set of calipers I'll be willing to part with cheap
  19. bensalf
    yorkshire ,england
    Ghost
    ghost,, are you actually saying you have a parts fiche for the xj600 pre diversion, european model?? if so i would love to obtain a copy if thats posible.
    and no there are no part numbers on the plastic covers, only a statement to remove them to check brakes, and the numbers 6.5 on the inside
    stu
  20. k-moe
    It would probably be more productive to check with the manufacturer of the caliper. It would have been sold to Yamaha as as assembly, and probably was only stocked by Yamaha as the entire assembly, including the cover.
  21. MiGhost
    Stu
    This is the part schematic that I referenced. For the US version Seca II XJ600.
    http://www.yamahapartshouse.net/oempart ... 00sd-parts
    Not sure if it is the one you are looking for.
    Ghost
  22. bensalf
    yorkshire ,england
    Stu
    www.yamahapartshouse.n...00sd-parts
    nope ,afraid not thats the equivelent of our xj600 diversion, mine's a pre diversion model.
    cheers
    stu
  23. johnnyx
    johnnyx Member
    london ont
    Yeah sorry no part number on my cover-and my area dealer doesnt list it on there site either-i will let you know when i go in and try to order some.
  24. adrian1
    adrian1 Active Member
    Has anyone contacted XJ4EVER yet about these covers?
  25. bigfitz52
    Man, ya beat me to it.
    The only place I can find them, fiche-wise, is in the USA-model 900RK diagram. But who knows if they're the same? Len does, betcha.
  26. RickCoMatic
    Those Plastic Covers are a little bland.
    I paint the Raises Lettering on them.
    Easy!
    Put-on a Latex to Nitrile Exam Glove.
    (Grab a few next time you go see the Doctor or Dentist)
    Make sure the Index and Middle Fingers are pulled-on tight.
    Place one drop of TESTORS Enamel Model Car or Railroad Paint on a 3X5 Card or Business Cars.
    Spread the drop FLAT on the Card with a NEW Safety Razor.
    Wait 45 seconds to one minute.
    Using INDEX Finger, ... Roll finger on Paint in a "Fingerprinting maneuver"
    Delicately ROLL your Finger across the Raised Lettering, ... transferring the Paint from your Gloved Fingertip to the Top edges of the Raised Letters.
    Repeat as necessary until letters are nicely colored.
    Raised Letters on Instrument Cluster.
    New Number-2 Pencil.
    Cut Pencil in half.
    Chuck the Eraser-end in your Drill so you can SCULPT the Eraser.
    Spin Eraser in Drill
    Sculpt Eraser to a babies-butt smooth CONVEX Dome. (400 Grit Paper)
    Smooth Convex Dome with 800 and 1000.
    Same one drop Razor spread flat maneuver as stated above.
    Touch ERASER's CONVEX Tip to the Paint on the Card.
    Transfer Paint from Eraser Tip to tiny Raised Letters under Dash Lights.
    Its better to use very little Paint several times, ... than try to do the Dash lights all at once.
    Filling recessed letters. (Master Cylinder / Crank Covers.
    Mask-off Letters with Black Electrical Tape'
    (Rectangular perimeter ... NOT Individual Letters)
    Pour Drop of Paint on Card
    Gloved Index Finger
    Collect whole drop.
    Wipe Paint across recessed letters filling recesses spreading paint over complete masked-off area.
    When Paint dries until tacky, ...
    Wrap Index Finger with clean cotton T-shirt,
    Moisten T-shirt with Lacquer Thinner.
    Touch finger tip to paper towel to absorb thinner so finger-tip is MOIST ... not Saturated.
    Make ONE PASS over Painted recessed lettering, ... wiping-off surface of Paint within masked lettered.
    Reload!
    Start with a fresh, clean section of Tee-shirt on finger.
    Thinner.
    Dab-off saturation 'til moist.
    Wipe!
    ONE PASS.
    Repeat 'til masked area is wiped clean of paint not in the recessed lettering.
  27. adrian1
    Beautifully done Mr Comatic. BTW is electrical tape your preferred masking off tape?
  28. RickCoMatic
    'Yes. Electrical Tape is a Custom Painters friend.
    You mask-off "The line" with Vinyl, ... using it to create a non-bleeding, straight or curved line.
    After creating The Edge with the Vinyl, .... regular masking tape gets laid-on the Vinyl along with paper or plastic sheeting.
