1981 SUZUKI GS 650
Discussion in 'Other Motorcycles' started by wizard, Mar 31, 2013.
  1. wizard
    Can't do anything with it at the moment, except sit on it & make brrrm brrrrm noises.
    GS 650
  2. Polock
    Re: 1981 SUZUKI GX 650
    sometimes that's all you need.
  3. bigfitz52
    You're back in the UK?
    Looks cleaner than most of the bikes you latch onto.
  4. wizard
    Yes, back in Blighty, Fitz. Bike looks OK, know more when I pick it up.
  5. adrian1
    adrian1 Active Member
  6. Bushy
    Bushy Active Member
    :0)
  7. wizard
    Just brushed some of the dust off, making a tentative start, rotor cover is cracked, found a s/h on the bay, had to drill & re-tap one of the bolt holes.
    GS650
  8. wizard
    Starter motor in need of some TLC.
    GS
  9. spinalator
    spinalator Member
    Regina, CANADA
    Yikes! Is it as bad as it looks?
  10. wizard
    Still working fine, believe it or not.
  11. wizard
    Comp' test shows 150 psi across the 4, I will put the valves in spec & test again, but looking good, so far.
  12. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Can't wait to see the job you do on this one Wiz
  13. wizard
    It never looked this bad from the top.
    SEAT PAN
  14. wizard
    Valve clearance, using Polock's plastic shim replacements.
    Method:
    Take all readings.
    Remove the shims that need changing & slip in the plastic shims, you can then go on turning the motor without damaging cam lobe or bucket, sort out all your swops & replacements.
    Makes life a whole lot easier.
    PLASTIC SHIMS
  15. wizard
    Seat refurbished using the original cover & foam / pan.
    seat
  16. wizard
    Started on the carbs, diaphrams look OK P/M screws I have pulled, were at 1-3/4 turns, all looking fine.
    CARBS
  17. bigfitz52
    That side-pull choke linkage is a thing of beauty. Interesting to see cast "hats" too.
  18. wizard
    Motor running fine, smoked a lot at first but cleared. Pictures of mk2 bike lift & 4 into 2 pipes I found, but need headers for 2 & 3.
    Will start the strip down.
    4 into 2
  19. wizard
  20. thietkelogo
    thietkelogo New Member
    Vietnam
    i still like this one made in 1981
  21. wizard
  22. wizard
    Repairing worn kick stand foot.
    Cut & level worn area, weld in new piece of 3mm M/S.stage one
    stage two
    all better
  23. wizard
  24. wizard
  25. wizard
  26. shangovi
    shangovi Member
    Burtonsville MD
    Hi - was the silver part on the swing arm painted? if yes what paint - it looks awesome...:)
  27. wizard
  28. shangovi
    shangovi Member
    Burtonsville MD
    Thanks wizard.
  29. wizard
    Pictures showing rot cut out, cardboard template & repair.
    4://www.flickr.com/photos/125682896@N02/14885466950/]3[/url]
  30. wizard
  31. wizard
  32. wizard
    Good Bridgestone rubber, new buttonhead s/s bolts to rotor.
  33. wizard
    GS REAR WHEEL 001.JPG Rear wheel picture
  34. wizard
  35. wizard
    GS REAR MC 001.JPG GS REAR MC 002.JPG Rear MC rebuilt.
  36. wizard
  37. wizard
    GS PROGRESS 1 003.JPG PROGRESS
  38. Polock
    Looking good, will this one be a keeper?
  39. wizard
    No space, Polock, if I want another project, it will have to go. ;o(
  40. wizard
  41. markie
    markie Member
    Suffolk, England
    I noticed the different newspapers used - now its the Sunday express! I like the woof keeping you company!
  42. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    your doing it man it's lookin NICE!!!!
    Keep up the good work.
  43. wizard
  44. k-moe
    3/4 of the fun is doing the work. I only keep one rider myself and let the projects pass on to someone who appreciates them.
  45. wizard
  46. wizard
    Further progress. GS PROGRESS 3 001.JPG GS PROGRESS 3 002.JPG GS PROGRESS 3 003.JPG
  47. Polock
    you didn't get overspray all over your garage door like you did in Australia, good job
    how many times did you hit your shin on that bike jack ?
  48. wizard
    numerous & ripped my pants leg.
  49. wizard
    GS FINISHED 001.JPG GS FINISHED 002.JPG GS FINISHED 003.JPG GS FINISHED 004.JPG GS FINISHED 005.JPG GS FINISHED
  50. Notoriusfastguy
    Notoriusfastguy Member
    Texas
    Pretty bike looks great! As a point of reference on the lift;
    I saw one on the net the same as yours but they cut it in 1/2 and stretches it about 4' added steel and welded everything it made a very nice lift and the handle/ part that sticks out was in front of the front wheel. I'll look for pics.
