xj550 sitting for ten years// first bike
Discussion in 'XJ Technical Chat' started by irritateddave, May 15, 2013.
  1. irritateddave
    irritateddave Member
    Virginia
    Hey everybody,
    Just got xj550 (first bike) from grandfather that he had in a barn for ten years. I soon found out after a new battery that they don't just start up. So now got carbs out (first carb cleaning (whoa!!)). Still waiting for main jet seals as two were missing to get back together. Getting ready to oil change and brake fluid change. New tires on way. My question is if there is anything else very important that I should be checking/replacing before I try to start bike again. Thanks.
    New to xjbikes but have not got off site for 3 days.
  2. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    Brake lines are good for 4-5 years. Yours should be changed before you ride. Back brakes should be checked for delamination. Stopping is far more important than going forward.
    In the going forward, there will be suggestions from the Wizards about your valve clearances, etc, and they'll give you a sequence. Trust them, and do things in that sequence, it all relates together.
    Welcome to the addiction!
  3. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Rear brakes for delamination, and front brake hose lines (probably 30 years old, 4-5 year life)
    To START.
    Valves gotta be in spec before you can sync the freshly-serviced carbs.
  5. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Replace the fuse block and fuses with automotive blade-style fuses. If it hasn't failed it will
  6. Krafty
    Krafty Member
    Point Clark ON
    ^^ good idea captainkirk,
    any idea on a good place to acquire a blade style fuse block to wire in?
  7. mtnbikecrazy55
    Fleet farm, any autoparts store, Len, eBay, availible many places.
    Then just grab a handful of assorted fuses out of cars, next time you're at the local pick n pull
  8. Captainkirk
    Captainkirk Member
    Northeast Illinois
    +1
  9. irritateddave
    Virginia
    Ok, definately will check out blade fuse box. As far as valves, whats a link for step by step. Also do I need to set gap on new plugs? Who are the wizards?
  10. mtnbikecrazy55
  11. mtnbikecrazy55
    Update your signature as well so people can help you easier in the future
    Welcome!
  12. irritateddave
    Virginia
    Ok I think I got a picture in but I'm not sure about signature. Ill keep trying tho.
  13. mtnbikecrazy55
    the part below my post - that lists my bikes V V V V
    V V V V V V V V V V V V V V V V V V V V V V V V V
  14. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    congrats on your first project bike! sitting for 10 years you are very brave! for sure start with valves and carbs, oil change (and other fluids as well) get that back tire off and check out the brakes im sure they will need repalcing. basically give everythign a one over. there are a ton of write ups on here on how to to just about everything, and some great videos on youtube if you know how to search (check out youtuber mrmaxstorey). good luck!
  15. cdilmore
    cdilmore Member
    Pittsford, NY
    Dave, welcome!
    That's a great first bike. You'll be rewarded for your careful and thorough work - sweet summer, autumn rides. And the satisfaction of bringing a classic back to life. Not everyone has the focus to achieve that, but you will. (And we're here to help along the way.)
    peace
  16. irritateddave
    Virginia
    alright, oil change and pulling off covers to take a swing at valve clearances today, and hopefully my main jet seals show up today and hopefully I hear her purr, right? Then brakes and brake lines. Thanks guys for the warm welcome.
  17. irritateddave
    Virginia
    Hey, signature thing worked.
  18. irritateddave
    Virginia
    OK, so I finally find drain plug for oil, and when it drained it seemed like there was nothing but stale gas in there. Waterlike consistency. Is that from where I was trying to start the bike with seized up carburetors or is pretty characteristic of ten year old oil to lose its texture.
  19. irritateddave
    Virginia
    also, how can I load up pictures to a thread. And thanks guys for support. I hope I can get her going, cuz I would definitely consider that a good accomplishment.
  20. k-moe
    The easiest way is to use a free photo hosting site. I like Photobucket.
  21. irritateddave
    Virginia
    Ahhhhhhh!!!!! I am going to need a lot of help here I think. So I hooked up the carburetor and went to prime and gas started running out of the second air boot. Now heres what ife done prior. I completely stripped down carbs, pullef out all jets that are removable then I boiled them in water and lemon juice. I gave everything a carb spray down with 2+2. It was shining. I then checked float needles by blowing in them and moving float up and down. One didn't quirk due to rubber tip damaged. I replaced it. I did a dry measurement on floats and all were the sane measurement +/- 1/64". I replaced float seals. Im scared to do a wet set because of mass confusion when trying to learn how. Anyway, any thoughts would be appreciated.
  22. irritateddave
    Virginia
    Ok, so I think I got the idea how to do the float check thanks to ravens suggestion about youtube except mrmax showed clear tube on a nipple at the bottom out the float bowl. So how do I hook one up to mine where I have a "female" drain?
  23. cutlass79500
    lawrenceville georgia
    First things first get it started. then worry about all the rest of the stuff before riding. Hope not but it could need rings or something after sitting that long. After its running then set the valves and sync the carbs. Then you can work on the brakes and other things. But if it was me get it running make sure the motor is good before spending any more money. Hate to see you jump in blowing a lot of money then find out the motor is bad. More then likely its not better safe then sorry
  24. irritateddave
    Virginia
  25. irritateddave
    Virginia
    Thanks cutlass. Thats a huge fear of mine mostly because I think my wife might strangle me in my sleep but I am very optimistic. I an concerned about trying to start bike at this point because the gas is pouring out so fast. However,i am very inexperienced in the ways of all things motorcycle and will attempt starting bike if I'm not going to blow myself up. Thanks for the help.
  26. Straitwalker
    Straitwalker New Member
    New York
    I hope not too many people are throwing you private messages, I am brand new to the forum as well and bought xj550 81, with similar problems. I have already had the carbs off twice and just got it back from a shop where it sat for four weeks waiting to be serviced to no avail. I am interested in hearing and seeing what does it for you, hoping it might work for me as well :)
  27. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Straitwalker - sent you a PM
    Irritateddave, sounds like you got a stuck float, or the wet set is off. Any time you service your carbs, always verify your wet set.
    You also need to change your oil + filter before you try to run it.... as you got gas pouring into your cyls too....
  28. bigfitz52
    Get over being scared, it's not uber difficult. The process is explained in detail here: http://www.xj4ever.com/setting%20fuel%20levels.pdf Once you get them 100% you can forget it for a while.
    As for the Mikuni's lack of a "nipple" for the drain hole, just make up a little plastic "fitting" from a vacuum hose fitting turned to size in your electric drill using a file. I used one from the auto parts or stole it from my Mity-Vac kit, I forget.
  29. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Like this:
    IMAG0394 by buellosaurusrex, on Flickr
    1/4" aquarium tubing, cut to desired length. Bend a piece of house wiring into the desired "L" shape and slide tubing over the copper wire. Heat the tubing with a heat gun until soft and pliable, then quench it in cold water. Tubing will retain the L shape.
    Heat the short end to soften, twist into bowl opening and allow to cool in bowl. Remove when cool. Voila! Wet-set tube.
    I made up a coiled holder bracket by wrapping gardening wire around a screwdriver. This holds the tube stationary when the springy ends of the brackets are inserted in the air bleed holes.
  30. irritateddave
    Virginia
    First of I want to apologize for all the crazy missaspellid word, my cell phone gets a little wacky sometimes.
    As far as floats go, should i remove air box and set on bike with bike on center stand because I have no way of getting that PVC thing.
  31. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    i found that the clear hose that comes with new batteries, that is used to fill the acid level fits perfectly in the female port of the carb bowl. just make sure its clean and not been used for acid first. mine came with a second small piece so it was perfect.
  32. irritateddave
    Virginia
    Thats a good idea. I do actually have a battery hose. I also found some tubing but alas, no heat gun. At least until my brother comes tuesday.
  33. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Dave, if yours is a Seca, the airbox won't come out. The boots will, but not the airbox. Not without a SawzAll, anyway...
    You should be doing the float heights off the bike anyway. Drop the bank.
    If you remove the airbox boots the bank will come out easily from the left side where you can then remove the throttle cable. Easy as pie. Now you can set the bank on a table and level them to check wet set.
  34. irritateddave
    Virginia
    Thanks. Mine is a maxim but I still can't see a way to remove air box. So.....assume that youre saying to set them on the float bowls level. Level side to side and front to back?
  35. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Yep. You can use a level across the domes side to side and a small level, if you have one, fore & aft. I use a torpedo level or string level for that.
  36. irritateddave
    Virginia
    Feeling good bout it now. I have actually been to the link mr fitz gave me a couple of times, but this is the first time I understood what I was reading. Guess I'm finally starting to learn a second language. I'll keep you guys posted, straight walker I've only got one pm so youre right with me.
  37. bigfitz52
    Actually, you pull the bank of carbs out from the right. (The starter is in the way on the left.) With the tank off, it's easy to unhook the throttle cable from the 'stub' cable before you remove the rack.
    On the 550s, there are three bolts into the TOP of the airbox. One is under the tool tray; you remove that one and loosen the two up on the slotted bracket just below the rear of the tank, below the frame backbone. Then you can slide the airbox rearward a few CM allowing for more clearance for the rack.
  38. Captainkirk
    Captainkirk Member
    Northeast Illinois
    I just did it with no issues?
    Maybe because the boots, tank and side covers were off? IDK....
  39. irritateddave
    Virginia
    Looks like two stuck floats but I can't get the blasted pins out. Scared I'm gonna break the towers. I'm probably gonna have to borrow a torch.
  40. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Dave, to get the pins out, do the following:
    Separate the bank, take off the carbs that need work.
    Place the head side on a 1/4", 1/4 " drive deep well socket or barely open jaws of a bench vise
    Lightly tap the end of the pin using a small diameter pin punch
    You should not need a torch, and you'd probably "torch" your carbs in the process.
    The reason they are so tough coming out is that the end of the pin is not round, but rather, flattened to prevent the pins from coming out on their own.
  41. RickCoMatic
  42. irritateddave
    Virginia
    ok got bank apart and checked one float which was good before i had to go back to work........again......sigh
  43. cutlass79500
    Spray the heck out of the pin with carb spray if the gas has gotten hard on the pin this will clean it off. Also if the pin does not move one way try the other. Sometimes the flattened out end of the pin gets put in the opposite way if they have been apart before.
  44. bigfitz52
    In the Mikuni carbs, the float pin has a "fat" area just below the head that binds into the float tower. The non-head end of the pin is a slip-fit, the "retaining" is going on right below the head of the float pin, if that makes sense.
  45. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    The most important thing you need is Kriol it is great for loosening all kind of fasteners and things that are seized up.
  46. irritateddave
    Virginia
    watch this below:
  47. irritateddave
    Virginia
  48. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    it says your video is private
  49. irritateddave
    Virginia
    ok try again. sorry
  50. irritateddave
    Virginia
    Hey guys, I bringing up this thread again because it pretty much covers everything I've done up to this point and I read in the "newbs do this" forum that I should try to keep all post together to help troubleshooters. (Good tip) Right now the list done is:
    1. carbs cleaned *
    2. carb lowers new gaskets *
    3. wet set floats*
    4. bench synced*
    5. valves checked and then shims moved or replaced to get in spec*
    6. replaced spark plugs (wrong plugs but get to that in a moment)*
    7. vacuum synced carbs*
    8. screwed in pilots all the way then out 4 flats*
    9. new brake lines and fluid changed *
    * start indicates the things done to bike that I would not have been able to do without the help found on this forum. Thanks
    To be done
    1. new tires and rear shoes (this week-end hopefully)
    2. rebuild brake caliper
    Now to my next question. I read on some other forums about resistor
    cores and resistor plugs and how they do not go together. I remembered that I put in Autolite performance plugs (4164). I didn't know anything about resistors at the time, so I check the box. Whew!!! no "R"s anywhere. Just to be sure I checked the autolite website, and sure enough they were resistor type plugs. So today I went and bought the NGK D8EA (2120). When changing them I noticed that all four tips of the resistor type plugs in the bike are black. I know that indicates a rich mixture, but I don't know if I should change anything yet. The bike has not been on the road yet, so I couldn't really ride for any amount of time, and they were the wrong plugs to begin with. Sooooo, any thoughts? Thanks in advance
