Gear shifting...Clunky between 2nd and 3rd XJ650..
Discussion in 'XJ Technical Chat' started by morg65, May 22, 2013.
  1. morg65
    morg65 Member
    Dublin Ireland
    Hi all,
    Had problems recently with contaminated oil...and starter clutch issues. So changed to the correct oil and flushed a number of times.
    Starter clutch is behaving better now but still slips once in a while..Now I notice that shifting from 2nd into third is a bit clunky.. Any ideas.?
    Thanks,
    Morg.
  2. Myro
    Myro Member
    New Jersey
    in my no way expert opinion sounds like a worn shit fork
  3. adrian1
    adrian1 Active Member
    What oil is in it now?
  4. moellear
    moellear Member
    Lima, Ohio
    Not sure if it matters but have you examined the grooves on your clutch boss? The splines (grooves) may have a large enough indentation that its causing the friction & steel plates in your clutch assembly to clunk more prevalent ... just a thought I may not be correct... I got myself a different clutch boss for the 550 & smoothed out each groove where the plates ride. Even went to the extent of polishing too which may have been overkill but did notice a difference afterwords. This clunky issue only came up after you changed the oil several time?
  5. morg65
    morg65 Member
    Dublin Ireland
    Hi all,
    Someone put synthetic in her on a service which caused all sort of starter clutch problems.
    So I have changed the oil three times now and flusher her out too. She got some fuel in the crank due to a sticky float.
    All this time I am using 20w40 motorbike specific mineral oil.i notice if I go thru the revs a bit more before changing gear the clunk doesn't seem to happen. maybe I'm just changing gear too soon.?
