new battery
Discussion in 'XJ Technical Chat' started by yamahamaxim1982, May 15, 2007.
  1. yamahamaxim1982
    yamahamaxim1982 Member
    minnesota
    hi i have a problem on my xj750 maxim the light that tells me my abttery is low goes of and stays on all the time it did with my old battery and i just got a brand new one and it does it with it to could the sensor be bad of do i need to clean it some how? does any one know what to do in this case please let me know thank you ivan.
  2. yamahamaxim1982
    minnesota
    any on has any thing i could try to fix this
  3. Altus
    Altus Active Member
    London, Ontario
    Pull the sensor from the battery and clean it in some rubbing alcohol. Make sure the wire connectors are clean and tight.
    Anyone else?
  4. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Make sure that the battery is fully charged.
    Low battery might set it off!??
    Not sure just my guess.
  5. Nick
    Nick Member
    Vernon, BC Canada
    Do you even have the sensor in the battery?
    The sensor is a long probe with only one wire attached and you would have inserted it inside one of the battery cells.
  6. yamahamaxim1982
    minnesota
    yes i have the sensor and i did put it in the bettery thank you all
  7. Polock
    check the voltage at the battery when it's running maybe the alternator needs
    brushes
    or hook the lead from the probe to a +12v lead and it will never come on again
  8. britcan
    britcan New Member
    San Antonio TX
    whats the battery type # for a canadian xj750
  9. MN-Maxims
    My 750's had the same problem. The wire that connects to the battery sensor is a white wire with a red tracer. Follow that wire goes up and into the headlight. If you have a multi meter you can check your voltage at that connector. It should be aprox 4 to 6 volts on the wire that comes from the battery. The other wire goes into the ignition switch. Here is where the problem is on most bikes. The ignition switch has a set of contacts that disconnect the sensor from the computer when the switch is off. If the contacts in the switch are dirty the computer will not "see" the signal from the battery and trip your warning light. You can see if the switch contacts are dirty by bypassing the ignition switch at that connector. Jumper the two white wires with the red tracers at the connector inside the headlight. If the batt warning light goes out and the red light stops flashing you got it. If not you will need to remove the tank and check the connector under there.
    Just a note you can't leave the jumper wire on that connector the battery will drain down over night since it will not stop sending voltage to the computer.
    If the ignition switch is the culprit you can remove it and take the two little phillips screws out of the back and clean those contacts with a scotch brite and light machine oil. Lube it up with tune up grease and put it back in and see how every thing works. Good Luck
