Weird Electrical problem
Discussion in 'XJ Technical Chat' started by grngrn, May 27, 2007.
  1. grngrn
    grngrn New Member
    New England
    Hi, I'm new to the site. Looks great. I have a '82 maxim xj750j. It was running fine till one day I turned the key and none of my dash idiot lights lit. The only thing that came on was my Head and tail lights. The bike will start but no directionals or brake lights, no horn or tach. The voltage is 12.5 through the fuse block. Engine block grounds are clean. What next? Thanks
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If you still have the stock fuse block change it to blade style block
  3. Robert
    Howdy grngrn. Change your fuse block out with newer environmentally sealed blade fuse holders. Your problems will most likely go away.
  4. RickCoMatic
    "Finding" current in the Quarter Century Old Fuse Panel is an all-together different matter than the current passing across those brittle glass fuse lugs through the old style fuses; what!
    The terminal lugs securing the fuse ends deteriorate to such extent that they'll break-off and open the circuit without warning, I say.
    Their ability to grasp the metal end of the glass fuse becomes lost after time; and a resistance or immediate open circuit results, don't you know?
    Rather than replacing the Fuse Panel with a replica or a pricey Original one from manufacturer; a smaller and more reliable Fuse Panel can be obtained, substituted without great difficulty and is far less dear for the look-alike, I must say!
    Have you any idea how bloody difficult it is to type with British accent?
    Well ... Good day to you, then.
    Cheerio.
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    Bollocks! I do it all the time..... ya'll ....... sh*t!! I tried. :)
    My original fuse box did exactly that - deteriorate to the point where the posts got so brittle, as soon as I tried to crimp them a bit closer, they just broke off. Unfortunately I did not have time to wait for a blade style box to get shipped, so I went to autozone and picked up a 4-position glass tube style box, that magically fit inside of the original yamaha fuse enclosure (thanks to a little dremelling). I ended up soldering the wires to the posts instead of using crimp connections, but I dare for someone to break one of my solder joints :twisted:
  6. grngrn
    grngrn New Member
    New England
    Thanks Guys, I put new fuse box in and it worked but now there's another problem. The bike started ok for the first 10 times, now nothing happens when I push start, just the dimming of the headlight. Any thoughts?
  7. kevineleven
    kevineleven Member
    Columbus, Ohio
    Your engine is seized.
    Your battery is almost dead.
    You are using the hi-low switch instead of the start button.
    Your starter is fried
    Your solenoid is fried
    Those are my thoughts, some more valid than others.
  8. samsr
    samsr Member
    Colorado Springs
    meutral?
    Side stand switch/relay
    the on/off switch OFF
  9. grngrn
    grngrn New Member
    New England
    All set thanks. found a bad connection under the gas tank
